I need ASUS X415EP bios
  • xurplusxhop
    • Jan 2012
    • 34
    hi everyone, I need ASUS X415EP bios. I tried X515EA, it works but keyboard won't function normally. I tried clearing ME but failed. Pls help.
  • xurplusxhop
    • Jan 2012
    • 34
    Re: I need bios X515EA - X415EA Rev 6.1
    Attached is my original ASUS X415EP BIOS. Please help clearing ME. thanks
      • 20318
      Do you have X515EA on the motherboard QR code ? .How doesn`t the keyboard function normally ? ,there are some tools to fix Asus keyboards -> https://www.badcaps.net/forum/showpo...43&postcount=5
      • xurplusxhop
        • Jan 2012
        • 34
        QR code printed on the motherboard is X415EP.
        Laptop Bottom cover is X415EP-EB213T.
        Model: X415E
        • xurplusxhop
          • Jan 2012
          • 34
          Re: I need ASUS X415EP bios
          can someone please extract the 16mb bios file from this BIOS downloaded from official asus site? All I can get is 19mb bios file.
            • 20318
            Open it with a hex editor, see the word PFAT .The next step is to extract using AMI PFAT extractor, then it needs further editing to make it the correct size, its only a bios update,not a full image so it will need merging with your backup ,and optionally need the ME firmware cleaning,then after that you can copy the DMI from your backup to the new bios.
            If you can`t do that let us know.
            • xurplusxhop
              • Jan 2012
              • 34
              "failed to execute script AMI_PFAT_Extract"
              • hardware1
                • Sep 2021
                • 2898
                • N/A
                Here's your New BIOS, try it and give me the results.
                Serial Number: M9N0CV12M559378.
                You didn't mention the issue of this dump, next time remember to do that.
                all donations are welcome,
                • toniblank
                  • Aug 2018
                  • 25
                  • indonesia
                  Hi, Please help me with my laptop, I try to flash with X515EA , the keyboard works but some keys wont work and SSD wont detect
                  Is there any correct bios file for my unit ? The Model is Asus X415EP on the barcode and X415EA R6.0 printed on the motherboard
                  thanks
                    • 20318
                    Is there any correct bios file for my unit ? The Model is Asus X415EP on the barcode and X415EA R6.0 printed on the motherboard thanks
                    Please type the serial number, no pictures. https://www.badcaps.net/forum/troubl...before-posting
                    • toniblank
                      • Aug 2018
                      • 25
                      • indonesia
                      i am sorry, here my sn and complete pictures
                      S/N : MAN0CV026762408
                      Model : Asus A416EPO-VIPS752
                      Boardcode : X415EA R6.0
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • exerion5000
                        Bios Needed For Asus X515EA Pcb X415EA R2.0
                        by exerion5000
                        Asus X515EA_No Power_GD25B127D@SOIC8.rar
                        Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                        02-17-2025, 01:34 PM
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • Exclikers
                        ASUS X515EA - X415EA Rev 6.0 Bios Bin
                        by Exclikers
                        Hi, Please help me with my laptop, I have this ASUS X515 that has BIOS password. I try to flash with BIOS X415EA Rev 2.0 but the keyboard wont work.
                        Then I try to flash with X515EA , the keyboard works but SSD wont detect
                        Is there any correct bios file for my unit? The Model is Asus X515EA on the sticker and X415EA R6.0 printed on the motherboard.. please see the attached image
                        The attached Bios bin was the original BIOS but has a Password..
                        Thank you...
                        06-02-2022, 10:07 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
