Need bios for asus GV301Q
  • aahilkhan43
    • Feb 2020
    • 38
    pleace help me for bios.
    laptop was died. i checked volages ok.
    here dump file
    • 20311
    Re: Need bios for asus GV301Q
    here dump file
    Post the serial number and a picture of the QR code near the HDMI connector.
    • Haker5
      Banned
      • Mar 2015
      • 65
      • internet
      check and raport
      • aahilkhan43
        • Feb 2020
        • 38
        thanks for replaying.
          • 20311
          The one on the motherboard not on a cable .It doesn`t matter if you don`t want to take the board out. Try the bios posted above, if it works you can add your DMI with the attached files, as he hasn`t added it for you.
          • aahilkhan43
            • Feb 2020
            • 38
            here
            • aahilkhan43
              • Feb 2020
              • 38
              I try but not work.
                • 20311
                I try but not work.
                The bios at post #3 should be ok,so looks like you got some other hardware problem.
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • lrouw84
                  by lrouw84
                  Hi there,
                  01-28-2023, 01:31 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
