HP Zbook 15u G5 and help with eeprogrammer software
  • TPLinux
    • Apr 2023
    • 4
    • Sweden
    administrator_password = enabled
    family = 103C_5336AN HP EliteBook
    sku = 2WK45AV
    uuid = 234a5333-a16f-6ab4-d9f8-52786f714142
    serial: 5CG8346KB2
    Motherboard Manufacturer: HP
    Product Name: 83B2
    Version: KBC Version 04.6E.00
    Serial Number: PGWMB00WBB804M
    BIOS Information
    Vendor: HP
    Version: Q78 Ver. 01.23.00
    Release Date: 11/30/2022
    Address: 0xF0000
    Runtime Size: 64 kB
    ROM Size: 32 MB
    Characteristics:
    PCI is supported
    PC Card (PCMCIA) is supported
    BIOS is upgradeable
    BIOS shadowing is allowed
    Selectable boot is supported
    EDD is supported
    8042 keyboard services are supported (int 9h)
    Serial services are supported (int 14h)
    ACPI is supported
    USB legacy is supported
    Smart battery is supported
    BIOS boot specification is supported
    Function key-initiated network boot is supported
    Targeted content distribution is supported
    UEFI is supported
    BIOS Revision: 23.0
    Firmware Revision: 4.110
    I have a CH341A and have tried to solve this by myself but need some help. Its hard to find software for this who doesnt contain virus. Had some problem reading the bios chip.
  • TPLinux
    • Apr 2023
    • 4
    • Sweden
    Re: HP Zbook 15u G5 and help with eeprogrammer software
    Is the chip that should be read/programmed?
      • 22279
      Search the forum for NeoProgrammer , ASProgrammer , Colibri.
      Thats one of them,there are 2 chips on the board, both are WSON8.I hope you aren`t going to try connecting a SOP8 clip ?
      • TPLinux
        • Apr 2023
        • 4
        • Sweden
        What clip should I use? How do I figure out the other chip?
          • 22279
          Assuming you don`t have the tools to desolder the chips you can use a WSON8 pogo pin adapter,search the forum,its been mentioned many times.There are 2 different sizes so choose the right one.Alternatively solder some wires from the programmer adapter board to the solder thats opposite each pin,this method will be more reliable than using the pogo adapter.
          I think the other WSON8 chip is on the other side of the board,somewhere..
          • zlr8r
            Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
            by zlr8r
            Greetings
            I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
            Serial Number: 5CG3202C16
            Product #/SKU: 739P0AV
            CT Number: PRTUE00WBI30YX
            Description: HP ZBook Firefly 14 inch G10
            BuildID: 23WWWGAZ602#SABU#DABU
            Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
            MAC address not found.
            • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
            10-28-2025, 01:56 PM
          • kenkaniff
            HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
            by kenkaniff
            Product Name: HP Pro x360 Fortis 11-inch G9
            System BIOS: U94 Ver.01.08.00 10/06/2023
            Serial Number: 5CG31946F5
            SKU Number: 85W05EC#AK8
            Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
            This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
            I needed to remove bios password...
            10-01-2025, 04:32 AM
          • pwingman
            HP ZBook Firefly 14(G8) (PASS)(UNLOCK)
            by pwingman
            I forgot the password of the admin settings do I need to dump the original bios first?
            Code:
            System Information
                Manufacturer: HP
                Product Name: HP ZBook Firefly 14 inch G8 Mobile Workstation PC
                Version:
                Serial Number: 5CG1070BLR
                UUID: d996a728-d393-4bfb-a592-ac1f5fda2e7e
                Wake-up Type: Power Switch
                SKU Number: 2C9Q1EA#ABH
                Family: 103C_5336AN HP ZBook
            BIOS Information
                Vendor: HP
                Version: T76 Ver. 01.01.32
                Release Date: 03/26/2021
            09-25-2024, 02:41 AM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • q2v5
            Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
            by q2v5
            Lenovo T480s
            Model 20L8-S3TE00
            Board ET481-U10
            Chip MX25L12873F
            Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
            2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
            The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
            08-15-2024, 10:40 PM
