Lenovo ThinkBook 15 G2 ITL Bios request
Hi shyiab.
Many many thanks for your efforts and i truly appreciate your help. The BIOS "kind of works" as it seems... It did boot up (it shows INVALID in PRODUCT NAME, MTM and SN, but i do not care too much now), i am able to enter the BIOS, it detects the HDD and everything seems to work as normal until i am trying to reinstall Windows via USB. I doesn't detect HDD to install to... I guess it has nothing to do with the BIOS but rather with the drivers for M2 NVME..
Anyway, i'm still looking for a solution, but the BIOS issue seems to be solved (at least for one of the laptops that i have worked on). Many thanks once again!
LE: I have succeeded to install UBUNTU, it seems it has no problem whatsoever... :-)
LLE: I've done it!!! It was the Intel VDM option in BIOS that prevented the drives to load... I have disable it and works like a charm...Comment
Hi shyiab.
Hi
can someone help me with BIOS
S/N: MP1Y16AR
LA-K052p Rev 1.0 board
Problem :power on but after 5 sec the led power off
after flashing the BIOS downloaded from here, there is power on, but no image
​Attached FilesComment
DEAR ALL
i have the above laptop m/b FLV35 LA-K052P REV:1.0
I DOWNLOAD BIOS FROM THE FORUM BUT I GOT VERIFICATION ERROR.
THE PROBLEM IS WHEN I INSTALL A NEW NVME DISK AND I AM TRYING TO INSTALL WINDOWS DOES NOT RECOGNISE THE DISK AND MOUSEPAD NOT FUNCTIONING.
IF I INSTALL NVME WITH WINDOWS, LOADS WINDOWS BUT KEYBOARD IS DEAD.
THE ATTACHED FILES ARE THE ORIGINAL FILES
CAN SOMEONE HELP!!!
THANKSComment
DEAR ALL
CAN SOMEONE HELP!!!
THANKSDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
hi try flash bothAttached FilesComment
Good afternoon,
LenovoThinkBook 15 G2 ITL Bios request,
The Model Name: ThinkBook 15 G2 ITL Laptop - Type 20VE
Serial Number: MP2581NN
Machine Type Model: 20VE012DIX
Problem black screenAttached FilesComment
Virgin bios + DMI.Comment
hello guys,
need clean and remove password of bios of 15 g2 itl lenovo laptop, here is the original dump :
s/n : MP21NX7D
MTM : 20VE0004fr
thank you as always !Attached FilesComment
hello
i saw after that i have two chips on this board, a 25q80dv (dump above) and 24c256 chip (dump here)
thanksAttached FilesComment
hello, yes i am confused
here it is : dumps of xm25qh64 and xmqh128 for this laptop, the chips were hidden by tape sorry
i have tried to use the virgin bios given by SMDflea and put sn and MTM in the 16mb file (25qh128) , flashed the 2 files (this one and the virgin one 25qh64).
the laptop start blank screen and high velocity fan.
i'm not sure this was the right method
can someone help me ?
s/n : MP21NX7D
MTM : 20VE0004FRComment
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by LurkyHello
I need help with Lenovo thinkbook 14 g7 IML clean bios file.
Computer has no display
Board : LTB14G7_INTEL_MB 233070-1 448.0UL20.0011
SN: PW0E172E
Dump attached please...-
by HotSaladMan*##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
Model : Lenovo ThinkBook 14S Yoga ITL
S/N : MP28JT19
MFG Date : 2022/02/09
Factory ID PRC4
MO : MPNXB26080FX
MTM : 20WE001US
MODULE FCC ID : PD9AX201NG
IC : 1000M-AX201NG
BOARD INFO
FLV34 LA-KO51P
REV : 1B 2020-08-24
Bit of Info
Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
chip id, so i would always uncheck the id check, so it would bypass the error
i did in fact make...-
by HammyCheesyHello all,
I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
Type: 30BB
Model Number: S03600
S/N: MJ07N68C
Things I have tried:
1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
2. Attempted to boot with just a single CPU...-
- Loading...
