Lenovo ThinkBook 15 G2 ITL Bios request
Hi shyiab.
Many many thanks for your efforts and i truly appreciate your help. The BIOS "kind of works" as it seems... It did boot up (it shows INVALID in PRODUCT NAME, MTM and SN, but i do not care too much now), i am able to enter the BIOS, it detects the HDD and everything seems to work as normal until i am trying to reinstall Windows via USB. I doesn't detect HDD to install to... I guess it has nothing to do with the BIOS but rather with the drivers for M2 NVME..
Anyway, i'm still looking for a solution, but the BIOS issue seems to be solved (at least for one of the laptops that i have worked on). Many thanks once again!
LE: I have succeeded to install UBUNTU, it seems it has no problem whatsoever... :-)
LLE: I've done it!!! It was the Intel VDM option in BIOS that prevented the drives to load... I have disable it and works like a charm...Comment
Hi shyiab.
Hi
can someone help me with BIOS
S/N: MP1Y16AR
LA-K052p Rev 1.0 board
Problem :power on but after 5 sec the led power off
after flashing the BIOS downloaded from here, there is power on, but no image
​Attached FilesComment
DEAR ALL
i have the above laptop m/b FLV35 LA-K052P REV:1.0
I DOWNLOAD BIOS FROM THE FORUM BUT I GOT VERIFICATION ERROR.
THE PROBLEM IS WHEN I INSTALL A NEW NVME DISK AND I AM TRYING TO INSTALL WINDOWS DOES NOT RECOGNISE THE DISK AND MOUSEPAD NOT FUNCTIONING.
IF I INSTALL NVME WITH WINDOWS, LOADS WINDOWS BUT KEYBOARD IS DEAD.
THE ATTACHED FILES ARE THE ORIGINAL FILES
CAN SOMEONE HELP!!!
THANKSComment
DEAR ALL
CAN SOMEONE HELP!!!
THANKSDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
hi try flash bothAttached FilesComment
Good afternoon,
LenovoThinkBook 15 G2 ITL Bios request,
The Model Name: ThinkBook 15 G2 ITL Laptop - Type 20VE
Serial Number: MP2581NN
Machine Type Model: 20VE012DIX
Problem black screenAttached FilesComment
Virgin bios + DMI.Comment
hello guys,
need clean and remove password of bios of 15 g2 itl lenovo laptop, here is the original dump :
s/n : MP21NX7D
MTM : 20VE0004fr
thank you as always !Attached FilesComment
hello
i saw after that i have two chips on this board, a 25q80dv (dump above) and 24c256 chip (dump here)
thanksAttached FilesComment
hello, yes i am confused
here it is : dumps of xm25qh64 and xmqh128 for this laptop, the chips were hidden by tape sorry
i have tried to use the virgin bios given by SMDflea and put sn and MTM in the 16mb file (25qh128) , flashed the 2 files (this one and the virgin one 25qh64).
the laptop start blank screen and high velocity fan.
i'm not sure this was the right method
can someone help me ?
s/n : MP21NX7D
MTM : 20VE0004FRComment
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by HotSaladMan*##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
Model : Lenovo ThinkBook 14S Yoga ITL
S/N : MP28JT19
MFG Date : 2022/02/09
Factory ID PRC4
MO : MPNXB26080FX
MTM : 20WE001US
MODULE FCC ID : PD9AX201NG
IC : 1000M-AX201NG
BOARD INFO
FLV34 LA-KO51P
REV : 1B 2020-08-24
Bit of Info
Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
chip id, so i would always uncheck the id check, so it would bypass the error
i did in fact make...-
by TecnicaNTTHi all,
I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
I am now asking here for help if anyone knows how to do this in...-
by HammyCheesyHello all,
I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
Type: 30BB
Model Number: S03600
S/N: MJ07N68C
Things I have tried:
1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
2. Attempted to boot with just a single CPU...-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
- Loading...
