Asus K513E no image, bios dump attached
  • f-bone
    • May 2013
    • 96
    • Greece
    Hi guys!
    I have this laptop which is turning on but has no image. I have attached the bios dump but I can't seem to find a working one. I also read a similar thread mentioning WBT.exe v314 but no instructions on how to use that.
    Can you please help me with a working binary that includes the DMI info from my dump? Or kick me to the right direction to try and add the DMI section myself? I used HxD on my dump and found the serial on multiple places so I am not sure what to copy.
    thank you very much in advance!
    br,
    george
    • 21968
    Re: Asus K513E no image, bios dump attached
    Originally posted by f-bone
    Hi guys!
    br,
    george
    Post the laptop serial number,also post pictures of the square white QR codes on the motherboard.
    • f-bone
      • May 2013
      • 96
      • Greece
      I hope this helps!
        • 21968
        I hope this helps!
        There`s a QR code just above the wifi card.Did you bend the heatsink up,it has a big dent in it .That could be the problem ? .
        • f-bone
          • May 2013
          • 96
          • Greece
          I saw the damages HS it wasn't me (I think that is not the problem, hs still works to a degree).. I try to be very careful with anything I try to fix.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Use engineering X513EANF1302 bios attached in this post:
            https://www.badcaps.net/forum/showpo...6&postcount=20
            Become a Badcaps supporter
            Thanks to all supporters.
            • f-bone
              • May 2013
              • 96
              • Greece
              great! what about DMI information? is it required here?
              (donated some money thank you for your efforts)
              EDIT2: tried X513EANF1302 but no luck, it won't turn on at all (previously I had power and fans spin). Stuck at 19.5V, 0.05A.
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                DMI is not a problem for the moment, the bios at the link should work as is, it's an engineering bios for your board, and if it's not booting with it, your problem is not bios related I'm afraid, if you're sure the chip is properly programmed and soldered to the board of course.
                Thank you for the donation, your support is much appreciated.
                • f-bone
                  • May 2013
                  • 96
                  • Greece
                  ok I will double check everything. should I also try X513EAF1313? apologies for the many questions, I will quit after this final try.
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    No. there's no point in trying to flash X513EAF1313 bios. You can see at image with the barcode - X513EAN
                    The F1 in the bios name stands for Asus engineering bios.
                    • f-bone
                      • May 2013
                      • 96
                      • Greece
                      thank you for everything. I will do my final checks and call it a day.
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        You're welcome
                        Yes, inspect the area surrounding the bios chip, and be sure you've programed the chip as it should, use verification. After programing the chip read the content and compare the files again.
                        BTW here's an older version of the bios for your board if you want to try one more file:
                        • f-bone
                          • May 2013
                          • 96
                          • Greece
                          thank you I forgot to report back!.. I gave it back to the customer before this last bios file but I kept it for a future repair. all the best to you guys.
                          • booba123
                            • Feb 2022
                            • 3
                            • france
                            hello, i have an asus k513ea with x513ea r5.3 mainboard, turn on cpu warm but no display on internal and ext monitor and white battery blinking 2times, so i think it's a bios issue,
                            i will attach the original bios and the one from asus website and maybe someone can do magic with both
                            • peste
                              • Dec 2016
                              • 13653
                              • ROMANIA
                              read..https://www.badcaps.net/forum/troubl...before-posting
                              • Berndt Christophe
                                • Apr 2024
                                • 9
                                • France
                                Hi
                                Asus K513EA Rev 2.0
                                Black Screen, 2x White Blinking Bios (Chip Gigadevice 25B127DS)
                                Do you have Bios, i'm tested differents Bios with CH341 ( setting with GD25Q128B) but nothing works Soft: NeoProgrammer
                                Thks for Help
                                Serial: 24M / M7N0CV22T82730D
                              • Berndt Christophe
                                • Apr 2024
                                • 9
                                • France
                                Do you find any solution for your problem? I'm same problem
                                • Berndt Christophe
                                  • Apr 2024
                                  • 9
                                  • France
                                  Hi
                                  Asus Vivobook K513E No GPU
                                  Problem Black Screen, 2x White Blinking Bios (Chip bios Gigadevice 25B127DS)
                                  Serial: 24M / M7N0CV22T82730D on Asus Website when i write this Serial i have :
                                  • Model: S533EA-BN1311T
                                  ​but i look chassis it's write K513E
                                  QR code Motherboard : X513EA
                                  do you have any idea? and the special Bios.bin?
                                  thks
                                  • NERI
                                    • Jun 2016
                                    • 20
                                    • slp
                                    Hello, good afternoon, I have a landfill with a password. Can anyone help me remove it? I attach team details.
                                    model: k513e
                                    sn: 12M/N2N0CV011236064
                                    MFD: 2022-02
                                    • peste
                                      • Dec 2016
                                      • 13653
                                      • ROMANIA
                                      model: k513e
                                      MFD: 2022-02
                                      try...
                                      • DynaxSC
                                        by DynaxSC
                                        06-14-2024, 03:49 PM
                                      • ArkzG
                                        [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                        by ArkzG
                                        Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                        What I currently have available:
                                        - Model: FA506NF (2021)
                                        - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                        - Tools: CH341A programmer ready to use
                                        Does anyone have either a clean 2MB .bin dump of this model,...
                                        09-26-2025, 09:34 PM
                                      • kcp0085
                                        Request BIOS dump for ASUS FA617NS
                                        by kcp0085
                                        Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                                        I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                                        Specs:
                                        - ASUS TUF FA617NS-A16
                                        - CPU: AMD Ryzen 7
                                        - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                                        If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                                        Thanks in advance!
                                        05-02-2025, 12:52 AM
                                      • Tamo Neko
                                        Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                                        by Tamo Neko
                                        I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                                        What Happened:
                                        I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                                        • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                                        • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                                        What I Need:
                                        • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                                        02-12-2025, 11:29 PM
                                      • grimacelord
                                        by grimacelord
                                        07-10-2025, 02:52 PM
