BIOS bin file for Lenovo Ideapad 3 17ADA6
  • carabas20
    • Jun 2023
    • 3
    • England
    Hello i need BIOS bin file for Lenovo Ideapad 3 17ADA6 S/N PF3AALFM.
    I have updated my bios from the official website , and after the laptop restarts it went to black screen and now i can not do anything. I have been trying to flash the bios with CH341A but from the office website i can see only the CAP file. I have need trying to modify the cap file following the guides and video from the forum but no luck.
    If anyone has a dump of original bios for this model will be great or clean the faulty bios for me , i have attached my backup bios
  • peste
    • Dec 2016
    • 12274
    • ROMANIA
    Re: BIOS bin file for Lenovo Ideapad 3 17ADA6
    bios extracted from Lenovo website update for IdeaPad 3-14ADA6, IdeaPad 3-15ADA6, IdeaPad 3-17ADA6...
    DMI 1000 - 2FFF
    • carabas20
      • Jun 2023
      • 3
      • England
      Thank you i will try to flash this one and I will update the results , thank you for helping me
      • carabas20
        • Jun 2023
        • 3
        • England
        DMI 1000 - 2FFF
        Thank you very much for your help , everything is working just fine , the only problem is when i go to the bios is says:
        MTM Invalid
        Lenovo SN invalid
        UUID Number Invalid
        I have attached a picture.
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          MTM Invalid
          Lenovo SN invalid
          UUID Number Invalid
          Read again post #2:
          DMI 1000 - 2FFF
          DMI block must be transferred from your bios backup to the new factory file using the above block addresses.
          Become a Badcaps supporter
          Thanks to all supporters.​
          • pcwhiz24
            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
            by pcwhiz24
            Model: Lenovo IdeaPad 3 14ADA05 81W0
            S/N: PF2BZS7D
            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
            I already have a CH341A programmer...
            04-07-2025, 07:10 PM
          • mximiliandz
            help bios lenovo ideapad s145-14iil type 81w6
            by mximiliandz
            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
            06-20-2025, 06:50 AM
          • survivalbloke
            Unable to extract bios file from Lenovo bios exectuable
            by survivalbloke
            I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
            Code:
            "innoextract 7wcn38ww.exe"
            it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
            The trouble I'm having is that I'm not getting the newly...
            06-12-2024, 07:55 AM
          • maanee11
            Help to get Lenovo BIOS bin file for Thinkpad T560
            by maanee11
            Hello Everyone,
            I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
            https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
            In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
            05-15-2022, 11:59 AM
          • Jk KIM
            Lenovo Ideapad 5 15ITL05 Bios File extract
            by Jk KIM
            Hi
            I need to extract bin file from bios update file which downloaded at Lenovo web site.
            Pls extract bin file from exe file...
            I attached exe file!
            Thx!...
            02-03-2023, 07:40 AM
