help I need bios HP ZBook Fury 15.6 inch G8 LA-K771P REV:1.0
  • rex98
    • Feb 2023
    • 1289
    • Mandaue CEBU, Philippines
    #61
    Originally posted by Drolltante@web.de
    Could someone please unlock these bios files.
    It s for a HPp zbook fury 15 G8.
    Would be a huge help.
    PN: HP ZBook Fury 15.6 inch G8
    ProdID: 4N4Z7AV
    SN: CND2120MWK
    Thanks a lot.
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU. you can permanently disable Absolute lock in BCU.
    u;r dmi:
    Serial Number: CND2120MWK
    Product #/SKU: 4N4Z7AV
    CT Number: PPGHLG2MYGELZX
    Description: HP ZBook Fury 15.6 inch G8 M
    BuildID: 21WWAVBT601#SABD#DABD
    Feature Byte: 3X476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbhcAdUdpdqfPhkk8mEmwn7nPnVngpD.8G
    MAC Address : A8:B1:3B:AC:22:EC​
    • hoaca388
      Badcaps
      • Jan 2022
      • 12272
      #62
      ProdID: 4N4Z7AV
      SN: CND2120MWK
      Thanks a lot.
      Password removed.
      • Drolltante@web.de
        • Aug 2024
        • 4
        Thanks a lot to both of you.
        should i do one of your Solutions, so only flashing the second chip for example what hoaca388 was suggesting or should i also do Rexer Anthonys approach?
        or both ?
        Thanks in advance
        i already flashed the first Chip BIOS_Dumps_HP_ZBook_fury_15_G8_WINBOND_25Q256JVEN_1er_Chip_2148_G134.rar so the Run2.bin and allready resoldered it with a BIOS where the password was removed by a friend. So all in all i am trying to get the second chipy (BIOS_Dumps_HP_ZBook_fury_15_G8_WINBOND_25Q256JVEN_2er_Chip_2153_6141_5D300) clean, without password in the bios.
        What would you suggest to do ?
        i am very new to all of this and ihave big trouble with all the soldering part. so idealy i have not to unsolder the first chip again. At least i hope so.
        Very big thanks
        • hoaca388
          Badcaps
          • Jan 2022
          • 12272
          #64
          or both ?
          Thanks in advance
          Very big thanks
          You can choose either method, whichever is convenient for you.
          • Drolltante@web.de
            • Aug 2024
            • 4
            Thank you so much !!!!
            It worked. I can use the Computer once again
            I Choosed the second option, because there was less soledring work to be done.
            • costin83
              • Mar 2023
              • 3
              • Romania
              #66
              Re: help I need bios HP ZBook Fury 15.6 inch G8
              Hi, I have HP Zbook Fury G8 with admin password.
              Serial# CND2202K5Y
              BIN file is attached.
              Thank you.​
              • rex98
                • Feb 2023
                • 1289
                #67
                Serial# CND2202K5Y
                Thank you.​
                here
                • costin83
                  • Mar 2023
                  • 3
                  • Romania
                  #68
                  Originally posted by rex98
                  here
                  Thank you !
                  • costin83
                    • Mar 2023
                    • 3
                    • Romania
                    #69
                    here
                    I know is a dumb question.
                    How do i write that back to the laptop ?
                    The extraction was done by a friend with his tools.
                    I know may way around computers but BIOS programing is something more delicate.
                    I saw many tutorials but i just want to do it the correct way.
                    Kind regards !
                    • sicilianul
                      • Jul 2014
                      • 70
                      • Romania
                      #70
                      Originally posted by hoaca388
                      CCC
                      Worked. Thank you very much !
                      • jymmytuan95
                        • Jan 2021
                        • 30
                        • Viet Nam
                        #71
                        i need bios la-k771p. bios old no power.
                        SERIAL CND3021B57
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12272
                          #72
                          SERIAL CND3021B57
                          HP ZBook Fury 15.6 inch G8 Mobile Workstation PC Wolf Pro Security Edition (63H12UT)
                          • jymmytuan95
                            • Jan 2021
                            • 30
                            • Viet Nam
                            #73
                            TKS A! bios kích nguồn ok nhưng báo 2 beep a..e có cặp bios này chạy lên hình nhưng báo lỗi Endpoint Security Controller Problem có fix được ko a?
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12272
                              #74
                              Post by English , please !
                              • jymmytuan95
                                • Jan 2021
                                • 30
                                • Viet Nam
                                #75
                                Endpoint Security Controller Problem​ done!
                                not detect ssd PCIe
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12272
                                  #76
                                  not detect ssd PCIe
                                  Clear Me
                                  • jymmytuan95
                                    • Jan 2021
                                    • 30
                                    • Viet Nam
                                    #77
                                    Clear Me
                                    TKS BRO! BIOS VERY GOOD
                                    • amirheidari681
                                      • Oct 2021
                                      • 43
                                      • iran
                                      #78
                                      hp zbook fury 15.6 inch g8
                                      sn: cnd20***** (scratched)
                                      GPZ50-LA-K771P-REV:1.0
                                      we have an error :
                                      HP Endpoint Security Controller Problem
                                      can any one correct the bios?
                                        SMDFlea commented
                                        Editing a comment
                                        Thread merged.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12272
                                      #79
                                      we have an error :
                                      • onlylove17
                                        • Jun 2021
                                        • 63
                                        • VN
                                        #80
                                        hello, you have clear ME help me ZBook Fury 17 inch G8 LA-K772P REV:1.0 NVME not working
                                        S/N: CND231069F
                                        P/N: 62D72PA
                                        thank you
