help I need bios HP ZBook Fury 15.6 inch G8 LA-K771P REV:1.0
  • rex98
    • Feb 2023
    • 1280
    • Mandaue CEBU, Philippines
    #61
    Originally posted by Drolltante@web.de
    Could someone please unlock these bios files.
    It s for a HPp zbook fury 15 G8.
    Would be a huge help.
    PN: HP ZBook Fury 15.6 inch G8
    ProdID: 4N4Z7AV
    SN: CND2120MWK
    Thanks a lot.
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU. you can permanently disable Absolute lock in BCU.
    u;r dmi:
    Serial Number: CND2120MWK
    Product #/SKU: 4N4Z7AV
    CT Number: PPGHLG2MYGELZX
    Description: HP ZBook Fury 15.6 inch G8 M
    BuildID: 21WWAVBT601#SABD#DABD
    Feature Byte: 3X476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbhcAdUdpdqfPhkk8mEmwn7nPnVngpD.8G
    MAC Address : A8:B1:3B:AC:22:EC​
    • hoaca388
      Badcaps
      • Jan 2022
      • 11809
      #62
      ProdID: 4N4Z7AV
      SN: CND2120MWK
      Thanks a lot.
      Password removed.
      • Drolltante@web.de
        • Aug 2024
        • 4
        Thanks a lot to both of you.
        should i do one of your Solutions, so only flashing the second chip for example what hoaca388 was suggesting or should i also do Rexer Anthonys approach?
        or both ?
        Thanks in advance
        i already flashed the first Chip BIOS_Dumps_HP_ZBook_fury_15_G8_WINBOND_25Q256JVEN_1er_Chip_2148_G134.rar so the Run2.bin and allready resoldered it with a BIOS where the password was removed by a friend. So all in all i am trying to get the second chipy (BIOS_Dumps_HP_ZBook_fury_15_G8_WINBOND_25Q256JVEN_2er_Chip_2153_6141_5D300) clean, without password in the bios.
        What would you suggest to do ?
        i am very new to all of this and ihave big trouble with all the soldering part. so idealy i have not to unsolder the first chip again. At least i hope so.
        Very big thanks
        • hoaca388
          Badcaps
          • Jan 2022
          • 11809
          #64
          or both ?
          Thanks in advance
          Very big thanks
          You can choose either method, whichever is convenient for you.
          • Drolltante@web.de
            • Aug 2024
            • 4
            Thank you so much !!!!
            It worked. I can use the Computer once again
            I Choosed the second option, because there was less soledring work to be done.
            • costin83
              • Mar 2023
              • 3
              • Romania
              #66
              Re: help I need bios HP ZBook Fury 15.6 inch G8
              Hi, I have HP Zbook Fury G8 with admin password.
              Serial# CND2202K5Y
              BIN file is attached.
              Thank you.​
              • rex98
                • Feb 2023
                • 1280
                #67
                Serial# CND2202K5Y
                Thank you.​
                here
                • costin83
                  • Mar 2023
                  • 3
                  • Romania
                  #68
                  Originally posted by rex98
                  here
                  Thank you !
                  • costin83
                    • Mar 2023
                    • 3
                    • Romania
                    #69
                    here
                    I know is a dumb question.
                    How do i write that back to the laptop ?
                    The extraction was done by a friend with his tools.
                    I know may way around computers but BIOS programing is something more delicate.
                    I saw many tutorials but i just want to do it the correct way.
                    Kind regards !
                    • sicilianul
                      • Jul 2014
                      • 70
                      • Romania
                      #70
                      Originally posted by hoaca388
                      CCC
                      Worked. Thank you very much !
                      • jymmytuan95
                        • Jan 2021
                        • 30
                        • Viet Nam
                        #71
                        i need bios la-k771p. bios old no power.
                        SERIAL CND3021B57
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11809
                          #72
                          SERIAL CND3021B57
                          HP ZBook Fury 15.6 inch G8 Mobile Workstation PC Wolf Pro Security Edition (63H12UT)
                          • jymmytuan95
                            • Jan 2021
                            • 30
                            • Viet Nam
                            #73
                            TKS A! bios kích nguồn ok nhưng báo 2 beep a..e có cặp bios này chạy lên hình nhưng báo lỗi Endpoint Security Controller Problem có fix được ko a?
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11809
                              #74
                              Post by English , please !
                              • jymmytuan95
                                • Jan 2021
                                • 30
                                • Viet Nam
                                #75
                                Endpoint Security Controller Problem​ done!
                                not detect ssd PCIe
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11809
                                  #76
                                  not detect ssd PCIe
                                  Clear Me
                                  • jymmytuan95
                                    • Jan 2021
                                    • 30
                                    • Viet Nam
                                    #77
                                    Clear Me
                                    TKS BRO! BIOS VERY GOOD
                                    • amirheidari681
                                      • Oct 2021
                                      • 41
                                      • iran
                                      #78
                                      hp zbook fury 15.6 inch g8
                                      sn: cnd20***** (scratched)
                                      GPZ50-LA-K771P-REV:1.0
                                      we have an error :
                                      HP Endpoint Security Controller Problem
                                      can any one correct the bios?
                                        SMDFlea commented
                                        Editing a comment
                                        Thread merged.
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11809
                                      #79
                                      we have an error :
                                      • onlylove17
                                        • Jun 2021
                                        • 59
                                        • VN
                                        #80
                                        hello, you have clear ME help me ZBook Fury 17 inch G8 LA-K772P REV:1.0 NVME not working
                                        S/N: CND231069F
                                        P/N: 62D72PA
                                        thank you
                                        • tcbucher
                                          BIOS Locked on Zbook Fury 17 G7 J203P Motherboard
                                          by tcbucher
                                          Been working to unlock a zBook Fury G7 17, SER# 2TK1380178.
                                          Has a removable MacronixMX25L256 BIOS chip. Have attempted to unlock the BIOS with multiple suggestions using a CH341A programmer.
                                          Any help unlocking the bios password would be appreciated. Bios attached.
                                          Thanks...
                                          12-13-2024, 11:34 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • reeza_plus
                                          HP ZBOOK FURY 16 G11 BIOS UNLOCK
                                          by reeza_plus
                                          MODEL: HP ZBOOK FURY 16 G11
                                          Hi please help unlock this bios
                                          SN: 5CG44640QC...
                                          03-19-2025, 05:12 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                          HP ZBook Fury 16 G10 Mobile workstation Specification for Upgrade or Repair
                                          This specification for the HP ZBook Fury 16 G10 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 G10 boardview and 16 G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                          09-07-2024, 07:20 AM
