HP 840 G8 Bios Unlock
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ---------------------------------------------------------------------------------------------------------------------------------------------------------------- -
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
hey guys
sorry for the inconvenience.
My notebook asks for a password when trying to access the bios and I don't know what it is.
HP EliteBook 840 G8
SN: BRJ146RKMZ
MAINBOARD: CORVETE - 6050A3217501 - MB - A01 (A1) (1086) L2
T76
Attached FilesComment
About HP 840 G8 Bios Unlock
Hello my friend
I think I did something wrong because I removed the eprom that is on the other side of the flash board and now it only flashes the light on the side and when it starts up the capslock turns on and turns off
hello everybody
I followed the procedure to configure the notebook in this message but after that the notebook would no longer start.
I don't know what I did wrong but now it just flashes an orange light. Please help me! I didn't find any topic related to this error for the HP 840 G8
Hello my dear friend! Can you help me unlock the BIOS of another laptop?
Model: HP EliteBook 840 G8
S/N: 5CG2236YPM
Board-Model: 6050A3426501-MB-A02
ProdID: 6B3S8UC#ABA
Chip-model: Winbond 25Q256JVENAttached FilesComment
Hello my dear friend! Can you help me unlock the BIOS laptop?
S/N: 5CG3061WYQ
Board-Model: 6050A3419601-MB-A01
ProdID: 4E0Q1EC#ABA
Chip-model: Winbond 25Q256JVEN | 2220 - 6206 - 21900
And one question, can I change the Bios, directly through Winduos, using hex, or do I need to make changes with the bios chip connected?Comment
Hi
S/N: 5CG3061WYQ
ProdID: 4E0Q1EC#ABA
Chip-model: Winbond 25Q256JVEN | 2220 - 6206 - 21900Comment
follow my friendAttached FilesComment
hello everybody
If it doens't work then you have probably damaged the eprom IC with heat, in that case try replacing the BIOS chipComment
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
by AkaBukaiHi there,
I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
The little LED on the power button is flashing slowly and nothing happen.
This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
So I decided to flash the BIOS using a cheap programmer.
And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
I also... -
by what_1282105Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
- Loading...
