BIOS for HP 15-ra009nia
  • ersiahmetaj
    • Jun 2022
    • 19
    • albania
    Hello I need bios for HP 15ra009nia, I have the old file and I downloaded bin files from HP official website, but there are 5 variants and I do not know which one to use. I will upload all of them, thanks anyone for help.
    • 24616
    Re: BIOS for HP 15ra009nia
    There`s no need to upload all 5,we can find them from HP support.You can find out which one you need using a hex editor, search for the word BID.
    If you don`t know how to do that you better wait for for someone to post a bios for you, with the DMI included.
    • ersiahmetaj
      • Jun 2022
      • 19
      • albania
      Re: BIOS for HP 15-ra009nia
      Ok thanks
        VIP Moderator
        • Aug 2018
        • 4387
        • Bulgaria 🇧🇬
        • Gadget & motorcycle addicted
        Next time add serial number to your request!!!
        CND01151R5
        Become a Badcaps supporter
        Thanks to all supporters.​
        • ersiahmetaj
          • Jun 2022
          • 19
          • albania
          It doesn't work
          It is still the same doesn't turn on the screen, if you remove the RAM it blinks in caps lock
          S/N CND01151R5
            VIP Moderator
            • Aug 2018
            • 4387
            • Bulgaria 🇧🇬
            It doesn't work
            In this case you have some hardware fault, and it's not a bios related issue. It's a virgin dump from HP support site, so you can't find any better one.
            • ersiahmetaj
              • Jun 2022
              • 19
              • albania
              It was normal, it doesn't turn on after BIOS Update. Any idea ?
                • 24616
                Sometimes,flashing an older bios version works. Go to HP support and download previous versions,start with the oldest then next newest and so on. Run the exe, choose "Save to location" ,all versions in that particular update will be decrypted and saved to the location you chose. Flash the "0832D.bin" .If none work then it could be the EC that needs flashing as well, or a hardware issue. You might have flexed the board too much, or disloged a cap or resistor or something ?
                • ersiahmetaj
                  • Jun 2022
                  • 19
                  • albania
                  I will try with an older version of BIOS
                  Can anyone send an older BIOS with DMI included
                  • cr4zychriss
                    by cr4zychriss
                    • Rebrand: PC Specialist
                    11-14-2025, 04:04 PM
                  • TopPop
                    Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                    by TopPop
                    Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                    I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                    12-14-2025, 09:40 PM
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • istvanszasz99
                    Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                    by istvanszasz99
                    Product ID: RZ09-0421
                    Motherboard: CH580
                    Bios File Size: 32,768 KB
                    Dear Forum Readers!
                    !!! MY RAZER BLADE...
                    11-24-2025, 05:52 PM
                  • george94
                    Gateway Laptop (gwtn141-10bl) won't post after enabling overclocking from bios
                    by george94
                    I have a laptop which i am trying to fix in which user enabled overclocking from bios and now it does not post.
                    Laptop with battery only: when power button pressed, power led lights for 10 seconds then turns off
                    Laptop with charger: white led in the charger and battery is charging, when power button pressed power led lights and it wont turn off
                    With multimeter i checked and i found out that:
                    EC chips gets 3.3 volts and it is not shorted (also no shorts on the board too)
                    Cpu power rail is fluctuating between 0 and 300 milivolts when charger is connected
                    01-27-2026, 02:42 PM
