lenovo e40-70 LA-B091P rev 1.0 need bios
  • soso technician
    • Nov 2019
    • 64
    • iran
    hi...i need bios for
    lenovo e40-70
    motherboard code LA-B091P rev 1.0
    i will send extracted dump from this main board with this post...thanks for your help.
  • soso technician
    • Nov 2019
    • 64
    • iran
    Re: lenovo e40-70 LA-B091P rev 1.0 need bios
    lenovo e40-70
    update...
    zip file 9dcn34ww is orginal exe file i got from lenovo with sn of laptop and file ZIWB2304 is 9m rom that i extract from orginal bios exe file...i cant edit this file to 8m rom....
    • lapfix
      • Mar 2020
      • 2724
      • my workshop
      update...
      Easy steps
      Open the main bios and 9m extracted from 9dcn34ww.
      From main select at second line = 5A A5 F0 0F ( Z¥ð) ans search for it at the 9m file...you find it than delete all the lines before to be match the begining of your main....that's your header
      Same thing with footer , select BF 50 41 EB 1D ( ¿PAë) and search for it at 9m ,...you find it than delete all after.
      That's all
      • soso technician
        • Nov 2019
        • 64
        • iran
        Originally posted by lapfix
        Easy steps
        That's all
        thank you so much for your time and guiding....i will try it....many thx again.
        • grimacelord
          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
          by grimacelord
          Hello there.
          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
          History:
          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
          I searched for this error online and discovered...
          03-15-2023, 03:29 PM
        • jendkkd jeje
          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
          by jendkkd jeje
          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
          10-11-2024, 03:12 PM
        • mximiliandz
          help bios lenovo ideapad s145-14iil type 81w6
          by mximiliandz
          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
          06-20-2025, 06:50 AM
        • 1g0r
          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
          by 1g0r
          First, the data in brief:
          Manufacturer: Lenovo
          Model: ThinkPad L15 G3 21C3-0016GE
          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
          IC Bios 1: MX77L25650F
          IC Bios 2​: MX25L25673G
          EC Chip: NPCX997KAABX
          So far I've been a silent reader, but now I need your help
          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
          01-18-2025, 02:39 AM
        • abhorsen
          Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
          by abhorsen
          Hey guys,
          Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
          Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
          Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
          07-06-2023, 10:22 AM
