Asus x412fl rev 2.0
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Asus x412fl rev 2.0
    I need help on this ASUS X412FL REV 2.0 can someone fix this bios please attached original file
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Asus x412fl rev 2.0
    need both main and ec please try to flash bios voltages present
      • 20900
      Post the laptop serial number and a picture of the white barcode sticker
      • String2016
        • Nov 2015
        • 2238
        • philippines
        serial:K8N0CV10M163349
        • String2016
          • Nov 2015
          • 2238
          • philippines
          and here is the white barcode
            • 20900
            This thread shows how to ID the correct bios version from the model on the barcode sticker -> https://www.badcaps.net/forum/showthread.php?t=96604 .The bios version you need is x412fl
            • String2016
              • Nov 2015
              • 2238
              • philippines
              https://www.asus.com/ph/supportonly/...helpdesk_bios/ does this one?can you please extract ec also
                • 20900
                Yes thats the right bios update.It needs extracting from the zip first, then use UEFITool to extract the body, then open the update with a hex editor,it is only a 7MB update so it needs editing to the right size. Then make a copy of your backup and open the copy and the 7MB update with your hex editor, merge/copy the 7MB over the last 7MB of your backup copy, then copy the DMI from your backup to the backup copy.Finally you clean the ME firmware then its ready to flash. The EC region is at the start of the 7MB update, if the EC file size is 128KB select 0-1FFFF as the off-set ,copy and paste into a new file,then save it.
                If you can`t do that wait for someone to help .
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  can someone help extract the ec please
                  • hardware1
                    • Sep 2021
                    • 2930
                    • N/A
                    Here is your EC file.
                    all donations are welcome,
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      @hardware 1 thank you can you fix this also my original main file above please
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        can someone fix this main bin also please
                        Last edited by Vesko356; 04-24-2023, 06:27 PM. Reason: Attached re-upload of the same file! Deleted!
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          Please read the rules before posting! Your request is in direct violation of the forum rules! There will be no further warnings about that, next time I'll delete your request!
                          Additionally you've attached the same bios dump again, did you read the sticky thread about the problems we have with the server low space? To re-upload the same file again in this situation is disrespectful to all of us to say the least.
                          I'm really disappointed to see that from a long-time member.
                          Become a Badcaps supporter
                          Thanks to all supporters.
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            Ok i understand.can someone fix the above main bios #1 post please
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              There's no need to break the rules, and to ask the same all over again! Enough said.
                              If you are in a hurry do it yourself, SMDFlea has already explained how it should be done.
                              Otherwise, you're waiting for someone to take the time to help you. That's it.
                              No one is obligated to do it right away or immediately. There's no need and it's against the rules to repeat your request again and again!
                              • sanjiv16
                                • Jul 2013
                                • 43
                                • philippines
                                ASUS X412FL REV 2.0 need bios
                                ASUS X412FL REV 2.0 need bios please because it indicate led when power but theres no display and the fan don't work. thanks in advance
                                here is my back up thank you
                                • laptopduy
                                  • Sep 2017
                                  • 5
                                  • TPHCM
                                  ASUS X412FL REV 2.0 I5 bios dump, Plz
                                  Please help me to fix this bios ASUS X412FL REV 2.0
                                  Thanks so much.
                                    • 20900
                                    Re: ASUS X412FL REV 2.0 I5 bios dump, Plz
                                    Thanks so much.
                                    Read post #3 and -
                                    • psinh99
                                      • Feb 2015
                                      • 53
                                      • viet nam
                                      I need help on this ASUS X412FL REV 2.0 , can someone fix this bios please.
                                      Serial: L1N0CV07J50403G
                                      ​The white barcode: (201) X412FAG
                                      My old bios
                                      My system can not power on.
                                      Thank advance
                                      • Lisa Su
                                        Badcaps
                                        • Apr 2021
                                        • 213
                                        • Taiwan
                                        X412FAG F1 Engineering BIOS
                                        X412FL F1 Engineering BIOS
                                        • Sebastian Codrean
                                          BIOS file for ASUS F542UN laptop
                                          by Sebastian Codrean
                                          Hello to all of you! I need help with a BIOS file.
                                          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                          02-20-2025, 10:25 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • caglarec2268
                                          Asus X515EA Bios File Please
                                          by caglarec2268
                                          merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                                          Now "please follow the steps below to recover your bios" text remains on the screen
                                          I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                                          laptop model x515ea-bq945w
                                          s/n: R4N0CV02K527148
                                          CN:HWFB
                                          Board model; ASUS X415EA R7.0
                                          bios chip: GD25Q128...
                                          11-27-2024, 03:51 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
