I need help on this ASUS X412FL REV 2.0 can someone fix this bios please attached original file
Asus x412fl rev 2.0
Tags: None
Re: Asus x412fl rev 2.0
This thread shows how to ID the correct bios version from the model on the barcode sticker -> https://www.badcaps.net/forum/showthread.php?t=96604 .The bios version you need is x412fl
.Last edited by SMDFlea; 04-24-2023, 01:53 AM.Comment
https://www.asus.com/ph/supportonly/...helpdesk_bios/ does this one?can you please extract ec alsoComment
Yes thats the right bios update.It needs extracting from the zip first, then use UEFITool to extract the body, then open the update with a hex editor,it is only a 7MB update so it needs editing to the right size. Then make a copy of your backup and open the copy and the 7MB update with your hex editor, merge/copy the 7MB over the last 7MB of your backup copy, then copy the DMI from your backup to the backup copy.Finally you clean the ME firmware then its ready to flash. The EC region is at the start of the 7MB update, if the EC file size is 128KB select 0-1FFFF as the off-set ,copy and paste into a new file,then save it.https://www.asus.com/ph/supportonly/...helpdesk_bios/ does this one?can you please extract ec also
If you can`t do that wait for someone to help .
.Comment
Here is your EC file.Attached Filesif you find these attachements useful please consider making a small donation to the site
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
@hardware 1 thank you can you fix this also my original main file above pleaseComment
Please read the rules before posting! Your request is in direct violation of the forum rules! There will be no further warnings about that, next time I'll delete your request!
Additionally you've attached the same bios dump again, did you read the sticky thread about the problems we have with the server low space? To re-upload the same file again in this situation is disrespectful to all of us to say the least.
I'm really disappointed to see that from a long-time member.
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
There's no need to break the rules, and to ask the same all over again! Enough said.
If you are in a hurry do it yourself, SMDFlea has already explained how it should be done.
Otherwise, you're waiting for someone to take the time to help you. That's it.
No one is obligated to do it right away or immediately. There's no need and it's against the rules to repeat your request again and again!
ASUS X412FL REV 2.0 need bios
ASUS X412FL REV 2.0 need bios please because it indicate led when power but theres no display and the fan don't work. thanks in advance
here is my back up thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: ASUS X412FL REV 2.0 I5 bios dump, Plz
Read post #3 and -
.Comment
I need help on this ASUS X412FL REV 2.0 , can someone fix this bios please.
Serial: L1N0CV07J50403G
The white barcode: (201) X412FAG
My old bios
My system can not power on.
Thank advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
X412FAG F1 Engineering BIOS
X412FL F1 Engineering BIOSAttached Filesif you find these attachements useful please consider making a small donation to the site
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
Hello to all of you! I need help with a BIOS file.
The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by caglarec2268merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
Now "please follow the steps below to recover your bios" text remains on the screen
I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
laptop model x515ea-bq945w
s/n: R4N0CV02K527148
CN:HWFB
Board model; ASUS X415EA R7.0
bios chip: GD25Q128...-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
