DELL Latitude 7430 bios
  • robbine75
    • Sep 2024
    • 8
    • us
    #41
    Originally posted by shiyab
    UNLOCK
    I am not lucky to get it work. I used CH341A to dump the original bios, but can not write bios. The error message: chip main memory with the contents are in disagreement. Then I bought a new program tool RT809F, the bios can be write without any error. After installed the chip, my computer doesn't show any response when press power button. I thought it maybe a bad bios file, then I flashed the original bios, the computer still no response to press power button. Is the computer bricked? What's possible reasons cause this problem? is there any solution I can try to get it work. Thanks.
    • Markus1741
      • Sep 2020
      • 979
      • N/A
      #42
      Hello, sorry but your original BIOS file is damaged.
      Unfortunately, this happens again and again with these CH341A programmers.
      The RT809F programmer is much better, especially since it also comes with good software from the manufacturer.
      I use the RT809H myself and am very happy with it.
      Try this version built from version 1.23.0 from Dell
      There's nothing like a good backup of the original BIOS and a clean programming of the file.
      Good luck​
      • Markus1741
        • Sep 2020
        • 979
        • N/A
        #43
        On the left in the picture is your damaged file, on the right is an intact file
        • robbine75
          • Sep 2024
          • 8
          • us
          #44
          Good luck​
          Thank you very much for the help. I flashed the bios you provided, but still doesn't work. before I hold ctrl+esc and then plug in power source, the power button will light up. now it looks the computer was not responsive to any button pressing. I think if the bios is bad, ctrl+esc method should trigger the bios recovery process and light up the power button light, right? I measured the bios vcc is only about 1.4v, I am not sure if this is normal voltage as I think the vcc should be 3.3v, right? is it possible the MB or keyboard is damaged?
          • Markus1741
            • Sep 2020
            • 979
            • N/A
            #45
            Hello, at 1.4 volts the BIOS doesn't even start; it needs 3.3 volts.
            I also bought a used motherboard on Ebay (Lenovo T490s) and then noticed that a diode over D2101 was missing and only 1.5 volts came to pin 8.
            In this case I replaced the diode and then it worked again.
            It would also be helpful to have a picture of the soldered chip.
            Upload a picture of your chip once.
            I don't know how advanced their equipment and skills are for such repairs.
            • robbine75
              • Sep 2024
              • 8
              • us
              #46
              Thanks for sharing the information. You're right. The diode around the bios chip is bad possible due to overheat when desoldering. I checked the diode forward bias is ~1.5v, which is not normal, it should be ~0.5v. The large bias pull down the vcc. I need to find the replacement, hopefully the problem would be solved.
              • Next2wireless
                • Dec 2023
                Is it solved after diode replacement, cause I'm facing the same issue no boot after programming the bios and just the fan getting spin continuously after plugin the battery
                And is it anyware related to USH part?
                • niggi
                  • May 2016
                  • 211
                  • UAE
                  #48
                  Originally posted by hoaca388
                  Re: DELL Latitude 7430 need clean me
                  aaaaaaaaaa
                  thanks u ok file
                  • danish8717
                    • Dec 2021
                    • 28
                    • united arab emirates
                    #49
                    dell latitude 7430 no display
                    ST-72WXVV3
                    mother board code LA-L582P
                    • Abracadabra100
                      • Jul 2023
                      • 7
                      • Spain
                      #50
                      Hi, can anyone help me to unlock bios
                      ST - 3GPV0T3
                        SMDFlea commented
                        Editing a comment
                        Thread merged.
                    • Akhlz001
                      • Dec 2018
                      • 33
                      • United Kingdom
                      #51
                      Could you post the bios file?
                      • Abracadabra100
                        • Jul 2023
                        • 7
                        • Spain
                        #52
                        I could only get dump from other laptop
                        • Abracadabra100
                          • Jul 2023
                          • 7
                          • Spain
                          #53
                          Here
                          • shiyab
                            • Sep 2023
                            • 1687
                            • india
                            #54
                            Originally posted by Abracadabra100
                            Here
                            post both file
                            • Abracadabra100
                              • Jul 2023
                              • 7
                              • Spain
                              #55
                              thats both chips that i found on mb, there was another one, but it looks like its for usb-c
                              • rex98
                                • Feb 2023
                                • 1297
                                • Mandaue CEBU, Philippines
                                #56
                                find the 8mb chip. its marked with 25q64
                                • Abracadabra100
                                  • Jul 2023
                                  • 7
                                  • Spain
                                  #57
                                  I found it on other side of MB, but 25q64 is low profile chip and i cant reach its pins without desoldering, but thats fine. Only problem i dont have tools with me to do that, but once i get them i will try to dump it
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12429
                                    #58
                                    https://shopee.vn/Bigdealsnice-Sop8-...2-a49d844c16a7
                                    • has don
                                      • Jul 2017
                                      • 10
                                      • ethiopia
                                      #59
                                      can anyone plz unlock bios admin password
                                      dell latitude 7430
                                      LA-L581
                                      SERVICE TAG 9X7GNN3​
                                      • shiyab
                                        • Sep 2023
                                        • 1687
                                        • india
                                        #60
                                        dell latitude 7430
                                        LA-L581
                                        hi try
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                          DELL Latitude 7430 Notebook 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude 7430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7430 boardview and 7430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7430...
                                          09-07-2024, 07:19 AM
                                          09-07-2024, 06:31 AM
