Request: Hp 14-fq0038ca bios
  • Adogabriel100
    knowledge seeke
    • Aug 2021
    • 36
    • peru
    Hey! This is a laptop HP. it came with a short on a mosfet. after replace it the machine turn on with no display. bloq mayus blink 5 large and 3 fast. (seems to be bios problem). i was trying to find a bios file for this but i found nothing
    Laptop model: 14-FQ0038CA
    Board: DA0PAEMB6D2 REV: D
    let the backup here:
    Thanks.
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Request: Hp 14-fq0038ca bios
    Thanks.
    Below is your bios with your DMI and Windows key transferred, if it's not working, most probably you have a hardware issue.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Adogabriel100
      knowledge seeke
      • Aug 2021
      • 36
      • peru
      I'm trying it right now. i ll tell u if work or it's time to measure again
      UPDATE: It does the same thing. thanks very much for your work and time. @Vesko356
      time to mesure again.
      Quik update 2: Short on AMD Chip. RIP
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
      • ebyte64
        Bios request for Acer P214-52-58CH
        by ebyte64
        Good day.
        I would like to request a bios for the following laptop?
        Model: Acer P214-52-58CH
        Model No: N19Q7
        S/N: NXVLHE0H11204BA27600
        SNID: 11201936276
        Symptoms: Laptop powers on but no picture on screen.
        I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...
        09-25-2024, 05:59 AM
