HP Elite Dragonfly G2 6050A3218601-MB-A01(A1) need BIOS unlock
  • stars-n-dust
    • Apr 2019
    • 59
    Please help removing the BIOS password, original dumps attached.
  • aldopc
    • Jul 2017
    • 477
    • Chilito
    Re: HP Elite Dragonfly G2 6050A3218601-MB-A01(A1) need BIOS unlock
    write U366, and keep your bin of U367.
    • stars-n-dust
      • Apr 2019
      • 59
      caps and num lock flashes 7 times and not powering on
      • anhbanxoi
        • Sep 2021
        • 180
        • VN
        I think you forgot to plug in the BIOS battery.
        • highping0r
          • Nov 2019
          • 15
          hey guys need your help. i have the same modell with a startup password. Already read U366 and ran it through RCUnlock but its still there. What can i do to get rid of it?
          SN:EDACC100CUM5D0BASU
          • Vesko356
            Vesko356 commented
            Editing a comment
            The serial number is wrong, Check again and post the correct one!
        • rex98
          • Feb 2023
          • 1296
          • Mandaue CEBU, Philippines
          the ec you sent is good. the bios password is also in main you need to send here the main bios.
          and serial number.
          • highping0r
            • Nov 2019
            • 15
            There it is
            • Vesko356
              Vesko356 commented
              Editing a comment
              Did you read my previous comment about the serial number?!
          • highping0r
            • Nov 2019
            • 15
            Sorry but the sticker is hard to read. Here is a picture for proof. I hope that´s fine?
            EDIT: Sorry but there is nothing on the outside or anywhere with the serial number
            EDIT2: Got it 5CG0248HCN
            • Vesko356
              Vesko356 commented
              Editing a comment
              This is not the laptop serial number. It's printed on the outside of the bottom cover!
          • rex98
            • Feb 2023
            • 1296
            It starts with 5CG
            you can also search 5CG in unicode string in EC using hex editor.
            if theres no SN we could not help you.
            • highping0r
              • Nov 2019
              • 15
              It starts with 5CG
              5CG0248HCN
              • Vesko356
                Vesko356 commented
                Editing a comment
                Read the chip with the main bios again, use verification. Posted dump is corrupted,
            • highping0r
              • Nov 2019
              • 15
              I did verify that i read it properly 3 times. Chip looks like someone was there already. Should i just use a Clean BIOS then?
              • Vesko356
                Vesko356 commented
                Editing a comment
                Of course not. Once the laptop is on and running, obviously the bios is fine (even with a password), you just need to read the chip properly, besides if you can't read it correctly, you won't be able to program it either.
            • highping0r
              • Nov 2019
              • 15
              Ok, first time using one of those clips. i put it on and read the chips 3 times and always same result. I guess i have to desolder like i was doing before and post the dump again.
              • Vesko356
                Vesko356 commented
                Editing a comment
                That would be the best approach. Using such gadgets almost always means a bad result.
                Also, it is necessary and very important to have a good and verified bios backup before doing any other experiments.
                You should read the chip at least twice (even better three times) and compare the contents between the dumps.
            • highping0r
              • Nov 2019
              • 15
              Yeah sucks to desolder especially in those tight ereas but it gives the best results. I always do at least 2 backups and compare them, no worries.
              • highping0r
                • Nov 2019
                • 15
                Next try. read it 3 times and verified that they are all the same, Please check
                • minhdigital
                  • Nov 2022
                  • 765
                  • Vietnam
                  Send to you
                  • highping0r
                    • Nov 2019
                    • 15
                    That worked !!! Thanks a lot
                    • lee20242024
                      • Aug 2024
                      • 5
                      • Fiji
                      sn/ 5cg0149cvx​
                      • EthanMai
                        • Jul 2020
                        • 103
                        • 美国
                        Please help me, need to cleaning.Thanks
                        HP ELITE DRAGONFLY G2
                        MB : 6050A3218601
                        SN : 5CG2060RG2
                        PID : 3Y372UC#ABA
                        • ace.code
                          • Apr 2016
                          • 133
                          • Estonia
                          i tried to clean this dump cause of problem with the fan always on high speed , plus me error on post
                          but i cant open the dump with fit
                          hp elite dragonfly g2
                          sn: 5CG1370R8X
                          fit error
                          Error 9: Failed to decompose Image.
                          Error 42: Failed to open with processed commands.
                          • peste
                            peste commented
                            Editing a comment
                            merged post..
                        • smd2222@yahoo.com
                          • May 2019
                          • 4
                          • iran
                          hi.I need a 32MB BIOS.and ec 32mg
                          u367-u366
                          • techlab
                            HP Elite Dragonfly Bios Crashed - HELP NEEDED
                            by techlab
                            Hi Guys,
                            Looking for some help with an HP Elite Dragonfly.
                            The customer explained it was updating the BIOS, the flashing completed, but afterwards the laptop wouldn’t power back on.
                            • The laptop has no power but does take the correct voltage.
                            • It shows 5 flashes white/amber, which indicates a BIOS issue.
                            • I backed up the original BIOS to extract the feature byte etc.
                            • I then flashed the BIOS with a clean version from HP’s website, but the laptop still gives 5 white/amber flashes.
                            Just wanted to pick your brains on this — has anyone come across this before or...
                            08-29-2025, 05:29 AM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • lee20242024
                            HP Elite Dragonfly G2 need BIOS unlock
                            by lee20242024
                            sn/ 5cg0149cvx​...
                            08-25-2024, 04:59 AM
                            HP Elite Dragonfly Hybrid (2-in-1) Specification for Upgrade or Repair
                            This specification for the HP Elite Dragonfly Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite Dragonfly boardview and Elite Dragonfly schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 03:21 PM
                            HP Elite Dragonfly Ultraportable Specification for Upgrade or Repair
                            This specification for the HP Elite Dragonfly Ultraportable can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite Dragonfly boardview and Elite Dragonfly schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 12:00 PM
