LA-J443P bios 1040 G8 CLEAR ME 100% worked
hello friends
i have a hp x360 1040 g8
when it powers on shows logo for a few seconds and turns off then turns on again and this time boots to windows and every thing is fine
i want to clear the me and i have read the main bios
but i cant open the file in any fit tool i have (this is 15.0)
i upload my original dump and please help me
i dont know what is the problem with fit tool
serial number: cnd0396w6rAttached Files -
hello friends
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
So this is not a bios error, check for hardware errors.
Hello, I need BIOS for Hp x360
HP x360 - 1040 G8
Mainboard GPM30 LA-J443P
Sn: CND14889BX
ThanksAttached FilesComment
You MUST:- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
"Hello, I have an HP 1040 G8 laptop with a touch screen that's not working, even in the setup. I've checked the connections and the flat cable, and everything seems fine. Could the problem be related to the BIOS file, or is it a hardware issue with the touch screen itself?"
"Hello, I have an HP 1040 G8 laptop with a touch screen that's not working, even in the setup. I've checked the connections and the flat cable, and everything seems fine. Could the problem be related to the BIOS file, or is it a hardware issue with the touch screen itself?"Comment
hello. i tried bios on #1 is working but have error HP Endpoint Security Problem Screen. please fix this dump. thank you
HP EliteBook x360 1040 G8 Notebook PC
Serial number: CND137BHHX
MB Code: LA-J443PAttached FilesComment
Anyone can help to change the serial number for HP EliteBook x360 1040 G8. Let me know if any information is needed.
Thank youComment
Every donation made will go towards server fees and maintenance costs.Comment
SN: CND3050ZRH need change to CND3051TQL
SKU Number : 489G2EC#UUF
System Board CT : PLMUEG3MYHPT6U
Product Family : 103C_5336AN HP EliteBook x360
Build ID : 21WWSKDT601#SUUF#DUUF
After that, what I need to do. I try to follow setup for DMI make pen drive as MS Dos, after boot with pen drive seems cannot boot.
This is the detail
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHowDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Yesterday, 03:01 PM -
by BloodhoundjeHi everyone,
I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
I have desoldered the bios chip (GigaDevice...-
- Loading...
