LA-J443P bios 1040 G8 CLEAR ME 100% worked
 hello friends
 i have a hp x360 1040 g8
 when it powers on shows logo for a few seconds and turns off then turns on again and this time boots to windows and every thing is fine
 i want to clear the me and i have read the main bios
 but i cant open the file in any fit tool i have (this is 15.0)
 i upload my original dump and please help me
 i dont know what is the problem with fit tool
 serial number: cnd0396w6rAttached Files
 HP EliteBook x360 1040 G8 Notebook PChello friends
 https://www.badcaps.net/donateComment
 So this is not a bios error, check for hardware errors.↵
 Hello, I need BIOS for Hp x360
 HP x360 - 1040 G8
 Mainboard GPM30 LA-J443P
 Sn: CND14889BX
 ThanksAttached FilesComment-
 You MUST:- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
 "Hello, I have an HP 1040 G8 laptop with a touch screen that's not working, even in the setup. I've checked the connections and the flat cable, and everything seems fine. Could the problem be related to the BIOS file, or is it a hardware issue with the touch screen itself?"
 Is it the original bios or a different one. Is it the original one with the password removed. Is the screen the original one or upgraded from a non touch version."Hello, I have an HP 1040 G8 laptop with a touch screen that's not working, even in the setup. I've checked the connections and the flat cable, and everything seems fine. Could the problem be related to the BIOS file, or is it a hardware issue with the touch screen itself?"Comment
 hello. i tried bios on #1 is working but have error HP Endpoint Security Problem Screen. please fix this dump. thank you
 Serial number: CND137BHHX
 MB Code: LA-J443PAttached FilesComment
 Anyone can help to change the serial number for HP EliteBook x360 1040 G8. Let me know if any information is needed.
 Thank youComment
 Every donation made will go towards server fees and maintenance costs.Comment
 This is the detail
 SN: CND3050ZRH need change to CND3051TQL
 SKU Number : 489G2EC#UUF
 System Board CT : PLMUEG3MYHPT6U
 Product Family : 103C_5336AN HP EliteBook x360
 Build ID : 21WWSKDT601#SUUF#DUUF
 After that, what I need to do. I try to follow setup for DMI make pen drive as MS Dos, after boot with pen drive seems cannot boot.
 post the contents of the bios chip even if it is corrupted..
 This is the detail
 The bios chip must be unsoldered from the board before writing or reading..
 do not use the clip, you may have errors..if you do not have anything to unsolder it with,
 solder wires between the programmer and the bios chip..
 you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHowDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
			by macabookHello everyone,
							Channel: BIOS Requests ONLY!
 07-24-2025, 02:17 PM
			by WahazHello,
 I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
			by lucaszmn
 Summary of BIOS Whitelist Removal Problem
 Problem:
 Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
 - I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
 08-12-2025, 03:01 PM
			by BloodhoundjeHi everyone,
 I have desoldered the bios chip (GigaDevice...-
- Loading...
