LA-J443P bios 1040 G8 CLEAR ME 100% worked
  • abbassink
    • Aug 2015
    • 83
    • iran
  • arashmoayyedizadeh
    • Jan 2022
    • 60
    • Iran
    hello friends
    i have a hp x360 1040 g8
    when it powers on shows logo for a few seconds and turns off then turns on again and this time boots to windows and every thing is fine
    i want to clear the me and i have read the main bios
    but i cant open the file in any fit tool i have (this is 15.0)
    i upload my original dump and please help me
    i dont know what is the problem with fit tool
    serial number: cnd0396w6r
    • hoaca388
      Badcaps
      • Jan 2022
      • 12043
      Originally posted by arashmoayyedizadeh
      hello friends
      HP EliteBook x360 1040 G8 Notebook PC
        • Jan 2022
        • 60
        • Iran
        hello sir
        thank you so much
        but laptop doesnt turn on with your bios
        woild you please clear my own bios?
        i could turn on the laptop with your bios but problem is the same
        turns on an shows logo then turns off and again on
        • hoaca388
          Badcaps
          • Jan 2022
          • 12043
          So this is not a bios error, check for hardware errors.
            • Jan 2022
            • 60
            • Iran
            thank you so much sir
            best regards
            • kesko
              • Mar 2022
              • 9
              • Österreich
              Hello, I need BIOS for Hp x360
              HP x360 - 1040 G8​
              Mainboard GPM30 LA-J443P
              Sn: CND14889BX
              • Vesko356
                Vesko356 commented
                Editing a comment
                You MUST:
                • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
            • kesko
              • Mar 2022
              • 9
              • Österreich
              Hello, the HP is starting and the fan is running for some seconds then it turn off. When I press Win + B and power on the laptop is running for 3 minutes without picture, f5 and f8 are lightning and then it turns off with a beep
              • niggi
                • May 2016
                • 195
                • UAE
                thanks you working file ok
                • Ahmed abdelwahed
                  • Mar 2025
                  • 7
                  • مصر
                  "Hello, I have an HP 1040 G8 laptop with a touch screen that's not working, even in the setup. I've checked the connections and the flat cable, and everything seems fine. Could the problem be related to the BIOS file, or is it a hardware issue with the touch screen itself?"
                    • 21394
                    Is it the original bios or a different one. Is it the original one with the password removed. Is the screen the original one or upgraded from a non touch version.
                    • quyet306
                      • Oct 2014
                      • 68
                      • saigon
                      hello. i tried bios on #1 is working but have error HP Endpoint Security Problem Screen. please fix this dump. thank you
                      Serial number: CND137BHHX
                      MB Code: LA-J443P
                    • juonbotak90
                      • May 2025
                      • Malaysia
                      Anyone can help to change the serial number for HP EliteBook x360 1040 G8. Let me know if any information is needed.
                      Thank you
                      • peste
                        peste commented
                        Editing a comment
                        post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                    • peste
                      • Dec 2016
                      • 13132
                      • ROMANIA
                      Thank you
                      post S/N, full name and model, motherboard model, .product number,,etc.
                      post the contents of the bios chip even if it is corrupted..
                      • juonbotak90
                        • May 2025
                        • Malaysia
                        This is the detail
                        SN: CND3050ZRH need change to CND3051TQL
                        SKU Number : 489G2EC#UUF
                        System Board CT : PLMUEG3MYHPT6U
                        Product Family : 103C_5336AN HP EliteBook x360
                        Build ID : 21WWSKDT601#SUUF#DUUF
                        After that, what I need to do. I try to follow setup for DMI make pen drive as MS Dos, after boot with pen drive seems cannot boot.
                        • peste
                          • Dec 2016
                          • 13132
                          • ROMANIA
                          This is the detail
                          The bios chip must be unsoldered from the board before writing or reading..
                          do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                          solder wires between the programmer and the bios chip..
                          you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                          • arslansharif
                            • Oct 2016
                            • 44
                            • pakistan
                            THANKS WORKING 100%
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
                            • Wahaz
                              by Wahaz
                              10-30-2023, 08:42 PM
                            • lucaszmn
                              by lucaszmn
                              Problem:
                              Initial Findings:
                              • I concluded that the
                              08-12-2025, 03:01 PM
                            • Bloodhoundje
                              HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                              by Bloodhoundje
                              I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                              I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                              After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                              I have desoldered the bios chip (GigaDevice...
                              03-16-2024, 03:12 PM
