Need bios dabkxmb18b0 rev b asus f15-tuf506lh-hn270
  • dihcar84
    • Aug 2012
    • 193
    • morocco
    10th g cpu
    MY OLD
  • hardware1
    • Sep 2021
    • 2898
    • N/A
    Re: Need bios dabkxmb18b0 rev b asus f15-tuf506lh-hn270
    10th g cpu
    MY OLD
    Here's your New BIOS, try it and let me know.
    Serial Number: N4NRCX084273178.
    all donations are welcome,
    • dihcar84
      • Aug 2012
      • 193
      • morocco
      thank you so much,thats ok
      • hardware1
        • Sep 2021
        • 2898
        • N/A
        Good to know, You're Welcome.
        • MSMxxx
          • Apr 2017
          • Ukraine
          Hi. A photo of the chipset area is required
          • mohammed mohan
            • Nov 2017
            • 196
            • z
            thank
            Mohammed Mohan
            • 789852
              • Nov 2015
              • 51
              • Kazahstan
              Need bios dabkxmb18b0 rev b asus f15-tuf506lhb-hn324
              Serial Number: N9NRCX03623836F
              • M4n0l0307
                • Nov 2020
                • 161
                • Colombia
                Thanks Friend !
                • amitswami
                  Delhi
                  • Aug 2021
                  • 38
                  • rajasthan
                  ASUS Gaming NOTEBOOK
                  ASUS FX506LHB-HN356W
                  BOARD NAME - DABKXMB18B0 REV : B
                  Product S/n - N6NRCX015325226
                  PLEASE​ REPAIR THIS BIOS
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • lrouw84
                    by lrouw84
                    Hi there,
                    01-28-2023, 01:31 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
