ezp2023 doesn't erase all of chip
  • dariuxzy
    • Mar 2023
    • 44
    • italy
    Hey, I'm trying to remove the password on my HP Elitebook 845 G7, so I have the two chips
    bios: MX25L25673G
    EC: 25Q256JVEN
    With EC I programmed the new edit bin file with ezp2023, everything worked, but when I erase MX25L25673G, the data is not completely erased. I'm going crazy, what should I do? Thank you
  • mon2
    • Dec 2019
    • 14863
    Re: ezp2023 doesn't erase all of chip
    Perhaps is write protected? Turn write protection off?
    • dariuxzy
      • Mar 2023
      • 44
      • italy
      how can I do? I don't think it can be done on ezp2023+ software
      • mon2
        • Dec 2019
        • 14863
        Just downloaded the software but unable to find this chip in their database.
        Which version is your software?
        See a speed setting. Configure to use the slowest setting and try to erase it again.
        • dariuxzy
          • Mar 2023
          • 44
          • italy
          i use the equivalent "MX25L25635E" (everyone uses this with this chip). I already tried erasing at low speed, but it didn't help. Software version 3.0
          • mon2
            • Dec 2019
            • 14863
            Erase the full chip. Then read it back and post the memory dump here.
            • dariuxzy
              • Mar 2023
              • 44
              • italy
              here it is. thanks
              • dariuxzy
                • Mar 2023
                • 44
                • italy
                Could it be that the chip is damaged? I have another "25Q256JVEN", can I replace it with "MX25L25673G"? They should be the same
                • anhbanxoi
                  • Sep 2021
                  • 180
                  • VN
                  I also got the same problem with this chip MX25L25673G. It's write protected but I managed to erase this chip with TL866ii and program the new bios file with ME cleared
                  • dariuxzy
                    • Mar 2023
                    • 44
                    • italy
                    i tried to program the bios with "25Q256JVEN" instead of the original chip "MX25L25673G", but now Power LED Blinking Orange continuously. Is it because the chip is not compatible?
                      • 22282
                      The ezp2023 is a very unreliable programmer.
                      • dariuxzy
                        • Mar 2023
                        • 44
                        • italy
                        do you recommend me to buy CH341a and use asprogrammer?
                          • 22282
                          The CH341A is another cheap programmer that has its own faults but i`d prefer it over the EZP. If you are going to buy one get one of the new 1.7 versions that has adjustable voltage,they are more expensive but come with a good selection of adapter boards. https://www.aliexpress.com/item/1005005047096231.html
                          You can use ASProgrammer,NeoProgrammer, Colibri and flashrom software
                          • anhbanxoi
                            • Sep 2021
                            • 180
                            • VN
                            I prefer xgecu T48. A bit more expensive but support a lot of chip and very fast.
                            • dariuxzy
                              • Mar 2023
                              • 44
                              • italy
                              Ok thank you. So do you think that the power led flashes orange because the chip is programmed badly?
