Thansk! It's for a A1708 Board 820-00840-A
A1708 - Clean BIOS Request
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by David GeeHello,
I am currently working on recovering my HP Laptop (Model: 17-cn0023dx) after a BIOS corruption issue. The laptop is stuck in a no-boot state, and the Caps Lock light is blinking with a 3.2 code (3 long, 2 short), which according to HP documentation indicates a BIOS corruption failure.
I have prepared a USB stick using the HP Cloud Recovery Tool, but I confirmed that it does not include a BIOS recovery image for Crisis Recovery. I also attempted to extract the BIOS file from the spXXXXX BIOS update package provided on the HP Support site, but that update only provides...-
- Loading...
