Asus K550J(X550JD) Bios need
  • babakmaku
    • Jun 2019
    • 40
    • Iran
    hi.i need asus K550J bios dump file
    X550JD rev2.0
    Core i7
    GTX 850M (N15V-GM-B-A2)
    IT8585E
    • 20286
    Re: Asus K550J(X550JD) Bios need
    X550JD rev2.0
    Core i7
    IT8585E
    Post pictures of the long white barcode stickers near the soldered RAM
    The reason why we need them is to see what model number is on it https://www.badcaps.net/forum/showthread.php?t=96604
    • babakmaku
      • Jun 2019
      • 40
      • Iran
      thanks for reply
      • hardware1
        • Sep 2021
        • 2887
        • N/A
        thanks for reply
        Here's your New BIOS, try it and let me know.
        Serial Number: F1N0CV62336905F.
        all donations are welcome,
        • babakmaku
          • Jun 2019
          • 40
          • Iran
          thanks bro.bios work very well but vga detected GT820M
          • hardware1
            • Sep 2021
            • 2887
            • N/A
            You're Welcome, try to re-install the GPU Driver or your OS, and last thing will be BIOS Update.
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • lrouw84
              by lrouw84
              Hi there,
              01-28-2023, 01:31 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
