Need bios for hp 250 g8 please
  • danito
    • Jun 2016
    • 1097
    Originally posted by Baron Strucker
    NEED BIOS FOR HP 250 G8 PLEASE
    PROD ID(27K11EA#A2N)
    SN# CND1485SZ5​
    try post #17
    • NTBservis
      • Jun 2016
      • 32
      • Czech
      Please for repair corrupted bios:
      HP 250 G8
      S/N: CND2283N48
      P/N: 59U09EA
      MB: LA-K201P rev 3.0
      • Blaze Tech
        Learner
        • 214
        • Ghana
        HP 250 G8
        S/N: CND2283N48
        P/N: 59U09EA
        TRY
        • NTBservis
          • Jun 2016
          • 32
          • Czech
          Working. Thanks
          • MathewP
            • Jun 2024
            • 9
            Hello all, need a bios for hp 250 g8
            MB
            MO: 71612217
            SPS: M31105-001
            Date Code: 7J2170
            SN: CND12870HJ
            ProdID: 2X7X9EA#ABB
            No display when it turn s on. Last message when it worked it was BIOS CHECKSUM ERROR 502.
            Thank you.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12333
              #26
              MB
              MO: 71612217
              SPS: M31105-001
              Date Code: 7J2170
              SN: CND12870HJ
              ProdID: 2X7X9EA#ABB
              Thank you.
              Where is your bios backup ?
              • MathewP
                • Jun 2024
                • 9
                #27
                I don t have it, last message was 502, after this message the display it s stay black(when i press power to shut it down, a gray display flash) and combination of power+winkey+b doesn t work.
                Thank you for your quick answer.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12333
                  #28
                  Do you know how to backup bios ?
                  https://www.badcaps.net/forum/troubl...rces-and-tools
                  https://www.youtube.com/results?search_query=ch341a
                  • MathewP
                    • Jun 2024
                    • 9
                    #29
                    Yes, i d make an usb fat32 with HP_TOOLS(HP System BIOS Update UTILTY) with my specified SN, for the first time was the message Flashing BIOS, after that message same problem, black screen and nothing else.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12333
                      #30
                      Backup bios via a Programmer.
                      • MathewP
                        • Jun 2024
                        • 9
                        #31
                        I don t know how to do that
                        • danito
                          • Jun 2016
                          • 1097
                          #32
                          read post #28
                          • MathewP
                            • Jun 2024
                            • 9
                            #33
                            MB
                            MO: 71612217
                            SPS: M31105-001
                            Date Code: 7J2170
                            SN: CND12870HJ
                            ProdID: 2X7X9EA#ABB
                            Thank you.
                            Finally the interface came and I was able to make backup.
                            in the archive is bk from: asprogrammer, mini programmer, neoprogrammer.
                            I need first to erase the chip? After erase I need to flash it?
                            thank you again!
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12333
                              #34
                              thank you again!
                              SSS
                              • MathewP
                                • Jun 2024
                                • 9
                                #35
                                SSS
                                Not ok, power light stay on for a second and after that it s turn off, I tried also without battery, same… 1 second stay turn on, after that it s turn off, no cooler start, nothing
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12333
                                  #36
                                  Find harware issues.
                                  • MathewP
                                    • Jun 2024
                                    • 9
                                    #37
                                    I did not modify the 341a adapter; I had read that it might be 5V, but the reading, erasing, or writing process was successful. I don't think the issue is from there. I will try to rewrite the backup to see if the problem persists. I will get back to you with a message.
                                    • MathewP
                                      • Jun 2024
                                      • 9
                                      #38
                                      Very strange, even with the old backup, it still doesn’t start. The LED stays on for 3 seconds and then turns off. What’s strange is that I can write/verify the BIOS without any problems. Before I started writing the BIOS, the laptop stayed on but had no display. What else can I try?
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12333
                                        #39
                                        Originally posted by saisoni20
                                        hoaca388 My Bad.
                                        It's LA-H32AP, 15s-GR0010AU with Ryzen 5 processor.
                                        I have attached bios dumb on #39
                                        You are wrong post.
                                        • mahlon simwnaja
                                          • Nov 2022
                                          • 84
                                          • south africa
                                          #40
                                          Good day
                                          Any one please help rebuild this bios
                                          FAULT : NO DISPLAY (caps lock code 5 long 3 short)
                                          S/N : CND14617QS
                                          BOARD MODEL NUMBER :GPP53 LA-H32AP
                                          BID : 087D1
                                          LAPTOP MODEL : HP 250 G8
                                          CPU TYPE : AMD RYZEN
                                          • glovecaps
                                            by glovecaps
                                            11-25-2024, 04:23 PM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • oragano
                                            ASUS ex-b250-V7 motherboard bios corrupted - by me
                                            by oragano
                                            hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                                            So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                                            i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                                            10-17-2024, 02:53 AM
                                          • AkaBukai
                                            Is it okay to flash stock bios onto the motherboard's BIOS?
                                            by AkaBukai
                                            Hi there,
                                            I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                                            The little LED on the power button is flashing slowly and nothing happen.
                                            This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                                            So I decided to flash the BIOS using a cheap programmer.
                                            And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                                            I also...
                                            12-19-2024, 12:15 PM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
