Dell Latitude 5521 - broadmoor 15 TGL-H BIOS file
  • cristiannec
    • Oct 2014
    • 48
    • Italia
    #41
    Originally posted by rex98
    try. on first boot be patient. reset security setting to defaults.
    Hello
    This bios reacts the same way as bios patched by me. Nothing happens when i press power button, not even the charger switch to 20v.
    Bios patched by @minhdigital ​starts, charger switch to 20volts, then sistem shuts down and restarts loop.
    • cristiannec
      • Oct 2014
      • 48
      • Italia
      #42
      Checked everything again,wrote each bin again and :
      - original bios everything works fine, just has bios password so board is fine. Click image for larger version
      - Bios from minhdigital stays on ~10 sec , then boot loop 1 sec on 1 sec off .
      - Bios from rex98 nothing happens, when i press power button i get amber light as long as the hold the button pressed. Charger does not switch from to 5 to 20.
      • volinakis
        • Jan 2021
        • 2748
        • N/A
        #43
        write again bios file provided by rex98, check soldering, at 1st start wait for 2 minutes, it will restart several times with no image.
        • cristiannec
          • Oct 2014
          • 48
          • Italia
          #44
          Replaced flash memory today, tried again, and :
          - Bios from rex98 starts , no image , and led flashes 3 amber 6 white.
          - Bios from minhdigital starts,after 2min display starts and dell logo appears for half a second, then system restarts continiously without an ending. (flashed it few times same result)
            • 21196
            Maybe there`s a hardware problem .The laptop is still under warranty = ProSupport Flex ⦁ Expires 18 NOV 2025​
            • cristiannec
              • Oct 2014
              • 48
              • Italia
              #46
              Don't think it's hardware issue, works fine with original dump, but has password.
              • Markus1741
                • Sep 2020
                • 852
                • N/A
                #47
                Try this file ...
                • minhdigital
                  • Nov 2022
                  • 758
                  • Vietnam
                  #48
                  Send to you, try again
                  • cristiannec
                    • Oct 2014
                    • 48
                    • Italia
                    #49
                    Originally posted by Markus1741
                    Try this file ...
                    Thank you, starts with backlight but no image, also 3 amber 6 white.
                    Thank you, starts, display logo, logo stays on, but nothing moves and 3 amber 6 white.
                    Posted a video earlyer but got deleted, probably broked some rules .
                    Thanks everyone for your support!
                    • minhdigital
                      • Nov 2022
                      • 758
                      • Vietnam
                      #50
                      One more time, good luck !!
                      • cristiannec
                        • Oct 2014
                        • 48
                        • Italia
                        #51
                        Hello, wrote it today, same behavior .
                        Starts , display dell logo, fan blows full speed and blinks 3 amber 6 white.
                        • rayeton
                          • 5
                          I have a Dell Latitude 5521 Bios locked with admin password
                          Board: 203040-1 BROADMOOR 15 TGL-H UMA
                          Service Tag: 8HVWT93
                          Express Service code: 18495782679
                          I've attached the original Bios dump.
                          Greatly apreciated!​
                          • rex98
                            • Feb 2023
                            • 1281
                            • Mandaue CEBU, Philippines
                            #53
                            1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode.
                            • rayeton
                              • 5
                              It worked without any problems.
                              Highly Appreciated!
                              • Kodza
                                • Jun 2016
                                • 191
                                • South Africa
                                #55
                                Hello guys I got Dell Latitude 5521, Broadmoor 15 TGL 203040 with bios password and computrace please help remove. service tag 635CGL3.
                                • rex98
                                  • Feb 2023
                                  • 1281
                                  #56
                                  1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode​
                                  • Kodza
                                    • Jun 2016
                                    • 191
                                    • South Africa
                                    #57
                                    Thank you Rex98, it worked
                                    • botez94
                                      • Aug 2023
                                      • 4
                                      • romania
                                      #58
                                      Hello guys ! i have a dell latitude 5521 sn 29m1sg3 and i lost original dumb. can you help me ?
                                      • ALEXSHAI
                                        • Nov 2020
                                        • Russia
                                        #59
                                        Hi there,
                                        I need bios for Dell Latitude 5521 - broadmoor 15 TGL-H UMA 203040-1 BIOS file.
                                        Service Tag: HDHPKG3
                                        Dump file is attached.​
                                        • devp62
                                          • 56
                                          #60
                                          Hi Can you pls remove computrace from this dump.
                                          Latitude 5521 Svc Tag HNGQHG3
                                          Many Thanks
                                            DELL Latitude 5521 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5521 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5521 boardview and 5521 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5521...
                                            09-07-2024, 06:40 AM
                                            09-07-2024, 06:31 AM
                                            09-07-2024, 02:50 AM
