Surface 3 BIOS dump for BIOS PW
  • SevenBIOS
    • Mar 2023
    • 11
    Hey guys, i have a surface 3 with a bios password which i cannot remember.
    I tried to dump the current bios with fptw64.exe thats what it says
    C:\Users\Admin\Desktop\bios>fptw64.exe -bios -d surface.bin
    Code:
    Intel (R) Flash Programming Tool. Version: 9.5.40.1868
    Copyright (c) 2007 - 2014, Intel Corporation. All rights reserved.
    Error 201: [FPTw64.exe] cannot be run on the current platform.
    Please contact your vendor.
    I dont know how to continue.. am grateful for help!
    EDIT: im not sure if its the right .bin in the attackment. If so, thx for decrypting
  • peste
    • Dec 2016
    • 12218
    • ROMANIA
    Re: Surface 3 BIOS dump for BIOS PW
    Code:
    the posted bios is empty... what programmer do you use???
    • hardware1
      • Sep 2021
      • 2888
      • N/A
      He used a Software called "fptw64" Flash Programming Tool.
      all donations are welcome,
      • hardware1
        • Sep 2021
        • 2888
        • N/A
        Code:
        It will be much better to use a Hardware Programmer for that job.
        Read that Post to learn:
        https://www.badcaps.net/forum/showpo...40&postcount=2
        • SevenBIOS
          • Mar 2023
          • 11
          Is there a way to get the dump.bin without opening up the surface? Just with software on windows?
            • 20276
            https://www.badcaps.net/forum/showpo...1&postcount=61
            • RethoricalCheese
              • Mar 2013
              • 1514
              • Estonia
              Nonononono, not on this model.
              All you need is a proper dump with fptw and then you can decrypt the password. Instead of opening the screen, soldering chip etc.
              • hardware1
                • Sep 2021
                • 2888
                • N/A
                Good, that's clear now, Thank you.
                • SevenBIOS
                  • Mar 2023
                  • 11
                  Hey, thank you for you answer, I tried to dump it with the exe but somehow it does not work.. i posted the error message at the beginning, could u help me with it?
                  • RethoricalCheese
                    • Mar 2013
                    • 1514
                    • Estonia
                    You used the wrong software. You would need to try ME95, ME11 and TXE2 windows versions. I don't know what "surface 3" exactly means in your case so... Just try all of them.
                    • SevenBIOS
                      • Mar 2023
                      • 11
                      I tried to Backup bios with Universal Bios Backup tool since i couldnt manage to do it with the other ones..
                      I hope it has the right stuff in it!
                      • SevenBIOS
                        • Mar 2023
                        • 11
                        Thats the Surface I use
                        • RethoricalCheese
                          • Mar 2013
                          • 1514
                          • Estonia
                          Look at your machine. There's model information written there. Some 4 digit code for example?
                          • SevenBIOS
                            • Mar 2023
                            • 11
                            Yes it says Model 1657
                            • RethoricalCheese
                              • Mar 2013
                              • 1514
                              • Estonia
                              So TXE2 I think.. Did you try that?
                              Are you trying it in windows or windows installation media?
                              If the first, are you running cmd as admin?
                              • SevenBIOS
                                • Mar 2023
                                • 11
                                I dont know if i am using the correct cmd..
                                I didnt know you can do it in installation media?
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1514
                                  • Estonia
                                  The command is correct. The question was, are you using the correct .exe file? You probably need TXE2 package instead of ME95 package which you used previously.
                                  Thatswhy I've told you to try TXE2, ME95 and ME11 because one of them must work.
                                  And yes, in installation media you can open cmd and do it from there. Atleast that is what I do all the time.
                                  • SevenBIOS
                                    • Mar 2023
                                    • 11
                                    I tried to find a working .exe file but somehow its harder than I thought..
                                      • 20276
                                      https://www.badcaps.net/forum/showthread.php?t=88533
                                      Intel Management Engine: Drivers, Firmware & System Tools
                                      https://winraid.level1techs.com/t/in...ols-2-15/30719
                                      Intel Trusted Execution Engine: Drivers, Firmware & System Tools
                                      https://winraid.level1techs.com/t/in...nd-tools/30730
                                      • shadow666
                                        Surface Book 3 1899_TOP Rev 2.0 Bios Dump
                                        by shadow666
                                        hello
                                        i need surface book 3 dump bios
                                        Model : 1899
                                        MB : 1899_TOP
                                        Rev 2.0
                                        Serial : 037248401157
                                        CPU :Core i7-1035G7
                                        Dump Bios problem is no power
                                        Problem is after update windows surface is blue screen after force shutdown , surface won,t turn on
                                        Regard...
                                        02-24-2025, 11:01 AM
                                      • Habble7
                                        by Habble7
                                        Suspected Cause:
                                        Troubleshooting Attempts:
                                        05-22-2025, 07:28 AM
                                      • kvanta
                                        Surface Pro 9 2038 need bios dump
                                        by kvanta
                                        Surface Pro 9 2038 BB_W MB SRLFP Intel Core i7-1255Usn 0f01juw23133bf need bios dump
                                        Hello, thanks for your reply, well you see I think I might have a corrupted bios because when I power on the surface pro 9 I get the windows logo comes on twice and then it turns off.
                                        I add the native BIOS, thanks!...
                                        08-20-2024, 03:34 AM
                                      • DynaxSC
                                        by DynaxSC
                                        11-17-2023, 10:56 AM
                                      • Kotp384
                                        Surface book 3 (1907) bios dump
                                        by Kotp384
                                        Hello everyone I really need a BIOS dump of surface book 3 (1907) 25R128jwpq. I just turned off the device and it didn't turn on anymore, it doesn't show any signs of life. Only the charging indicator lights up and goes out when the power button is pressed for a long time. All the voltages on the board are in order, there is a theory that the BIOS is somehow lost.
                                        I will be grateful for any help
                                        07-19-2024, 07:31 PM
