Lenovo g50-80 80e5
  • pooya_pm
    • Jan 2021
    • 258
    • iraq
    Lenovo g50-80 80e5
    Hi
    lenovo g50-80 80e5
    i need oFficial bios
    only ofFicial bios pls
  • lapfix
    • Mar 2020
    • 2756
    • my workshop
    Re: Lenovo g50-80 80e5
    Originally posted by pooya_pm
    Hi
    lenovo g50-80 80e5
    G50-80 Laptop (Lenovo) - Type 80E5
    This is a virgion bios , hope you know how to transfert your DMI
    [Mod. Edit] DMI offsets 29A000 - 29BFFF
    • pooya_pm
      • Jan 2021
      • 258
      • iraq
      Originally posted by lapfix
      g50-80 laptop (lenovo) - type 80e5
      this is a virgion bios , hope you know how to transfert your dmi
      no i dont know
      i can write this bios on ic?
      • pooya_pm
        • Jan 2021
        • 258
        • iraq
        ok thankyou
        • lapfix
          • Mar 2020
          • 2756
          • my workshop
          Yes you can , but you can upload your old dump here and somone will help you
          • pooya_pm
            • Jan 2021
            • 258
            • iraq
            yes you can , but you can upload your old dump here and somone will help you
            this is backup
            official bios not work bro
            • lapfix
              • Mar 2020
              • 2756
              • my workshop
              this is backup
              And the original !! what's your main issue !
              • pooya_pm
                • Jan 2021
                • 258
                • iraq
                and the original !! What's your main issue !
                no disply and restart
                • lapfix
                  • Mar 2020
                  • 2756
                  • my workshop
                  Try now
                  • ebyte64
                    • Jun 2023
                    • 51
                    • South Africa
                    Good morning.
                    Can I please request a bios for a Lenovo G50-80 (80E5)?
                    I have provided a copy of the original for DMI and winkey cloning.
                    Thank you very much.
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      Originally posted by ebyte64
                      Good morning.
                      Read the rules before posting:
                      You MUST:
                      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                      • Post what the problem is, be specific - black screen, no boot, running slow, password.
                        Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                      Become a Badcaps supporter
                      Thanks to all supporters.
                      • ebyte64
                        • Jun 2023
                        • 51
                        • South Africa
                        My apologies
                        I require a bios for the folowing Laptop
                        Lenovo G50-80
                        Model name: 80E5
                        S/N: PF0FF9RK
                        Board model: ACLU3/ACLU4 UMA NM-A362 Rev 1.0
                        Problem:
                        All voltages are present on the board but no image on screen.
                        tested new memory and new screen.
                        Using bench power supply to power laptop shows board drawing 15ma standy and 475a when power button is pressed so I can see the EC chip is working as it is monitoring the power button.
                        Cou also gets hot as I believe it should.
                        All voltages apropriatly present on board. This leads me to believe that it is possibly a bios issue.
                        I have already tried copying original bios DMI myself to a vergin bios but from the post I found regrding copying DMI for this laptop model I can find the start offset mentioned but not the end offset. Thus I am unsure how to poceed.
                        Help will be apreciated but if I am still in violation of rules I will remove my post.
                        Thank you all for your time.
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          My apologies
                          Lenovo G50-80
                          Model name: 80E5
                          S/N: PF0FF9RK
                          Problem:
                          You can use the bios in post #2 replacing the DMI from your backup.
                          • ebyte64
                            • Jun 2023
                            • 51
                            • South Africa
                            Thank you.
                            Yes I saw those offsets but my problem is when I look at the bios in a hex editor I cannot find the 29BFFFh offset. Only the start one. So not sure why this bios is diffrent. The last 29B entry in the original bios is 29BFF0.
                              • 21690
                              Thank you.
                              Offsets in your original bios Put your cursor on the last FC it will be 29BFFF .The first FC on that last line is 29BFF0
                              • ebyte64
                                • Jun 2023
                                • 51
                                • South Africa
                                Ah! I see where I went wrong.
                                Thank you so much.
                                • babakmaku
                                  • Jun 2019
                                  • 40
                                  • Iran
                                  hi.i need Lenovo G50-80-80E5 (ACLU3-ACLU4-NM-A361 rev1.0) Bios
                                  CPU : Pentium
                                  GPU : AMD
                                  MTM : 80e5024tax
                                  Backup Bios:
                                    • 21690
                                    CPU : Pentium
                                    GPU : AMD
                                    MTM : 80e5024tax
                                    Backup Bios:
                                    Post the serial number, read post #11 .
                                    • babakmaku
                                      • Jun 2019
                                      • 40
                                      • Iran
                                      Originally posted by smdflea
                                      post the serial number, read post #11 .
                                      pf08g8c8
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12276
                                        pf08g8c8
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • 1g0r
                                          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                          by 1g0r
                                          First, the data in brief:
                                          Manufacturer: Lenovo
                                          Model: ThinkPad L15 G3 21C3-0016GE
                                          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                          IC Bios 1: MX77L25650F
                                          IC Bios 2​: MX25L25673G
                                          EC Chip: NPCX997KAABX
                                          So far I've been a silent reader, but now I need your help
                                          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                          01-18-2025, 02:39 AM
                                        • c.daniel
                                          Lenovo V310-15IKB weird bios problem...
                                          by c.daniel
                                          Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                                          sn LR09493E
                                          MB DAOLV6MB6F0 REV. F
                                          The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                                          Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                                          Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                                          08-22-2025, 05:39 AM
                                        • abhorsen
                                          Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                                          by abhorsen
                                          Hey guys,
                                          Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                                          Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                                          Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                                          07-06-2023, 10:22 AM
