Lenovo g50-80 80e5
  • pooya_pm
    • Jan 2021
    • 259
    • iraq
    Lenovo g50-80 80e5
    Hi
    lenovo g50-80 80e5
    i need oFficial bios
    only ofFicial bios pls
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: Lenovo g50-80 80e5
    Originally posted by pooya_pm
    Hi
    lenovo g50-80 80e5
    G50-80 Laptop (Lenovo) - Type 80E5
    This is a virgion bios , hope you know how to transfert your DMI
    [Mod. Edit] DMI offsets 29A000 - 29BFFF
    • pooya_pm
      • Jan 2021
      • 259
      • iraq
      Originally posted by lapfix
      g50-80 laptop (lenovo) - type 80e5
      this is a virgion bios , hope you know how to transfert your dmi
      no i dont know
      i can write this bios on ic?
      • pooya_pm
        • Jan 2021
        • 259
        • iraq
        ok thankyou
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          Yes you can , but you can upload your old dump here and somone will help you
          • pooya_pm
            • Jan 2021
            • 259
            • iraq
            yes you can , but you can upload your old dump here and somone will help you
            this is backup
            official bios not work bro
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              this is backup
              And the original !! what's your main issue !
              • pooya_pm
                • Jan 2021
                • 259
                • iraq
                and the original !! What's your main issue !
                no disply and restart
                • lapfix
                  • Mar 2020
                  • 2764
                  • my workshop
                  Try now
                  • ebyte64
                    • Jun 2023
                    • 51
                    • South Africa
                    Good morning.
                    Can I please request a bios for a Lenovo G50-80 (80E5)?
                    I have provided a copy of the original for DMI and winkey cloning.
                    Thank you very much.
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      Originally posted by ebyte64
                      Good morning.
                      Read the rules before posting:
                      You MUST:
                      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                      • Post what the problem is, be specific - black screen, no boot, running slow, password.
                        Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
                      Become a Badcaps supporter
                      Thanks to all supporters.
                      • ebyte64
                        • Jun 2023
                        • 51
                        • South Africa
                        My apologies
                        I require a bios for the folowing Laptop
                        Lenovo G50-80
                        Model name: 80E5
                        S/N: PF0FF9RK
                        Board model: ACLU3/ACLU4 UMA NM-A362 Rev 1.0
                        Problem:
                        All voltages are present on the board but no image on screen.
                        tested new memory and new screen.
                        Using bench power supply to power laptop shows board drawing 15ma standy and 475a when power button is pressed so I can see the EC chip is working as it is monitoring the power button.
                        Cou also gets hot as I believe it should.
                        All voltages apropriatly present on board. This leads me to believe that it is possibly a bios issue.
                        I have already tried copying original bios DMI myself to a vergin bios but from the post I found regrding copying DMI for this laptop model I can find the start offset mentioned but not the end offset. Thus I am unsure how to poceed.
                        Help will be apreciated but if I am still in violation of rules I will remove my post.
                        Thank you all for your time.
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          My apologies
                          Lenovo G50-80
                          Model name: 80E5
                          S/N: PF0FF9RK
                          Problem:
                          You can use the bios in post #2 replacing the DMI from your backup.
                          • ebyte64
                            • Jun 2023
                            • 51
                            • South Africa
                            Thank you.
                            Yes I saw those offsets but my problem is when I look at the bios in a hex editor I cannot find the 29BFFFh offset. Only the start one. So not sure why this bios is diffrent. The last 29B entry in the original bios is 29BFF0.
                              • 22293
                              Thank you.
                              Offsets in your original bios Put your cursor on the last FC it will be 29BFFF .The first FC on that last line is 29BFF0
                              • ebyte64
                                • Jun 2023
                                • 51
                                • South Africa
                                Ah! I see where I went wrong.
                                Thank you so much.
                                • babakmaku
                                  • Jun 2019
                                  • 46
                                  • Iran
                                  hi.i need Lenovo G50-80-80E5 (ACLU3-ACLU4-NM-A361 rev1.0) Bios
                                  CPU : Pentium
                                  GPU : AMD
                                  MTM : 80e5024tax
                                  Backup Bios:
                                    • 22293
                                    CPU : Pentium
                                    GPU : AMD
                                    MTM : 80e5024tax
                                    Backup Bios:
                                    Post the serial number, read post #11 .
                                    • babakmaku
                                      • Jun 2019
                                      • 46
                                      • Iran
                                      Originally posted by smdflea
                                      post the serial number, read post #11 .
                                      pf08g8c8
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12441
                                        pf08g8c8
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • gestalt.exe
                                          Lenovo Legion Y540 – Need help repairing BIOS after bad downgrade
                                          by gestalt.exe
                                          My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
                                          Laptop stopped booting entirely.
                                          I used a CH341A programmer to dump the corrupted 16MB BIOS.
                                          i then attempted the following:
                                          1. Downloaded stock BIOS BHCN39WW from Lenovo
                                          2. Trimmed it to 16MB
                                          3. Extracted the BIOS region from the corrupted dump
                                          4. Extracted the BIOS region from the stock 39WW
                                          5. Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
                                          6. Injected back my LDGB / DMI
                                          Yesterday, 10:38 AM
                                        • to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                          by to5it0
                                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                          I have opened the laptop and identified the main BIOS chip...
                                          10-24-2025, 01:35 AM
                                        • mkdj
                                          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                          by mkdj
                                          Dear all,
                                          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                          Here the steps I have taken to fix the laptop:
                                          - downloaded latest BIOS from Lenovo Website...
                                          10-18-2025, 03:43 AM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
