Panasonic CF-19 MK1 request unlock bios
  • kasper1910
    • Mar 2023
    • 7
    • POL
    Hi Friends
    I got locked phoenix bios on my Panasonic CF-19 Mk1 (first version)
    I desoldered chip M25PE80VG and did full dump of bios on table.
    Can someone decode for me password or unlock bios dump or make universal bios image??
    HERE IS A DUMP (is it ok or someone in the past make something with it ??)
    Please help
    Regards
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: Panasonic CF-19 MK1 request unlock bios
    Originally posted by kasper1910
    Hi Friends
    Please help
    Regards
    The chip size is 1MB (8Mbit), it's a wrong chip. your BIOS chip should be 8MB or 16MB.
    all donations are welcome,
    • kasper1910
      • Mar 2023
      • 7
      • POL
      Thanks for reply.
      I got huge problem because I didn't see any another chip thats looks like bios flash. I also didnt see on any site chip for this kind of motherboard ….if I will put here photos of my motherboard…
      here are some photos of motherboard I will make better when I will arrive to home
      • WhateverGDR
        • Nov 2021
        • 22
        • Whereever
        Look the attachment.
        • kasper1910
          • Mar 2023
          • 7
          • POL
          I made dump exacly this chip if You look at this chip You can read that is 25PE80VG. I desoldered it and made dump on table. So if this is not correct chip so please help me find corect one…
          • kasper1910
            • Mar 2023
            • 7
            • POL
            Here is my motherboard. I dont see any another bios chip
            Link for better quality files:
            https://ibb.co/6DLsPY2
            https://ibb.co/8MRgY27
            https://ibb.co/fYvJ4JX
            https://ibb.co/Yym00N7
            I think that is a good bios chip . I found on site a bios-download „product/panasonic-cf-19-mk2-bios” where dump has 1 mb size. So early version CF-19 like MK1, MK2 had small size of bios chip. Version MK3 had 4mb dump size….
            • kasper1910
              • Mar 2023
              • 7
              • POL
              Anybody have a solution. Please help Community???
              • volinakis
                • Jan 2021
                • 2875
                • N/A
                that is bios chipset, mk1 and mk2 have 1Mb bios chipset.Anyway, your bios is edited, no serial, no product name, no chassis serial, etc.
                • kasper1910
                  • Mar 2023
                  • 7
                  • POL
                  Maybe someone before me edited it….. is any solution to restore this kind of data or delete password ???
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    08-07-2025, 04:54 AM
                  • sedat88
                    Panasonic CF-54DY024NG Bios Dump
                    by sedat88
                    I'm looking for Panasonic CF-54 bios dump.
                    Flash memory with bios is damaged and is not possible to recover any information from it.
                    Model Name - CF-54DY024NG
                    S/N: 6DTSA61473
                    Thank You...
                    09-29-2025, 03:03 AM
