Toshiba U840-DA0BY2MB8D0 REV.D
  • babanu
    • Jan 2011
    • 61
    Hello !!
    I have a toshiba satellite u840-10m with the motherboard DA0BY2MB8D0 REV.D Model BY2, which after almost 1 year of being unused at startup, this error appears!!
    I can't enter the bios!! I tried to rewrite the bios but I can't find it for this motherboard model!!
    If someone can help me
    Thank you
  • hardware1
    • Sep 2021
    • 2951
    • N/A
    Re: Toshiba U840-DA0BY2MB8D0 REV.D
    Originally posted by babanu
    Hello !!
    Thank you
    Upload your BIOS Backup here, write your Device Serial Number and someone will try to help you.
    all donations are welcome,
    • babanu
      • Jan 2011
      • 61
      thank you very much !!
      • hardware1
        • Sep 2021
        • 2951
        • N/A
        This file is a Virgin BIOS from Toshiba with your DMI, I hope it fix your Problem.
        • babanu
          • Jan 2011
          • 61
          It works !!!!
          thank you very much for your help !!! I appreciate
          • hardware1
            • Sep 2021
            • 2951
            • N/A
            It works !!!!
            Nice, You're Welcome.
            It takes me a long time to find the correct BIOS, I hate to deal with Toshiba Website, it's so hard to find what you are looking for. Besides this is an old Model.
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • cr4zychriss
              by cr4zychriss
              • Rebrand: PC Specialist
              11-14-2025, 04:04 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
            • jjkevi
              Lost MAC Address After BIOS Rewrite – Need Help Restoring on HP 800 G1 SFF
              by jjkevi
              I’ve run into an issue with my HP 800 G1 Small Form Factor PC after performing a BIOS rewrite. Everything works except for one major problem — the MAC address for the onboard network adapter is missing.
              Here’s the situation:
              • Model: HP 800 G1 SFF
              • OS: Windows 10 Pro
              • Cause: After rewriting the BIOS, the system lost its original MAC address.
              • Symptoms:
                • Network adapter shows a generic or invalid MAC (or sometimes blank).
                • No Ethernet connectivity unless I use an external USB-to-Ethernet adapter.
              • What I’ve tried:
                • Checked BIOS settings (no MAC override
              08-11-2025, 05:05 AM
