fdi55 la-j081p hard drive is not taken
  • DWCS
    • May 2021
    • 49
    • Sri lanka
    The lap came without power on, after doing the bios program it power on
    But after programming the bios, the hard drive is not taken help me
  • hardware1
    • Sep 2021
    • 2946
    • N/A
    Re: fdi55 la-j081p hard drive is not taken
    Upload your Original BIOS, write your device Model and Serial Number.
    all donations are welcome,
    • DWCS
      • May 2021
      • 49
      • Sri lanka
      someone try to repair before. so no to backup orginal bios
      Inspiron 3593
      Service Tag: GSSX953
      • hardware1
        • Sep 2021
        • 2946
        • N/A
        Inspiron 3593
        The only option for you is to try Dump files till the device works.
        Try this BIOS.
        • federalhouse
          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
          by federalhouse
          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
          **Background:**
          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
          **What I've Tried So Far:**
          1. I accessed
          08-01-2024, 07:03 PM
        • tmcw
          PC case - Hard drive rails
          by tmcw
          A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
          So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
          I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
          Now, the case is a CiT Gaming Case, and...
          05-22-2022, 12:04 PM
        • madura2010
          DAY11AM6E0 hard disk drive and optical disk drive not detected
          by madura2010
          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
          i checked the connectivity of ribbon=good communication with hard and motherboard
          changed hard disk and checked=3f0 error persist
          sata power=+5v available
          Then checked data capacitors=all good
          Then checked data lines path connectivity to pch=all good
          reflashed...
          03-12-2023, 09:09 AM
        • ash91
          Hp pavilion 15 not detect hard drive
          by ash91
          Hello gentelmen .... this is my first post and sorry for my bad english,
          so my proplem is my laptop keep losing hard drive even if i but the
          hard disk in the cady (the box that can replace the dvd rom with hard disk)
          when i turn the laptop on the massage that said no boot media found pop on
          the hard disk is fine and to be sure i try another hard
          i also update my bios to the last update
          the 5 volt is present on the hard connector on the motherboard
          the dvd rom work fine when i but a windows dvd in it
          also when i boot from flash...
          06-07-2023, 01:45 PM
        • karto95
          Repairing a Seagate hard drive with damaged logic board
          by karto95
          I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
          I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
          If anyone has any suggestions or experience with this...
          03-21-2023, 04:05 AM
