Samsung Np700z4a Bios
  • smallvhin
    • Jul 2015
    • 182
    • philippines
    Master help to my fix bios file.
    issue turns on samsung logo shows up but keep restarting cannot enter on bios setup
  • smallvhin
    • Jul 2015
    • 182
    • philippines
    Re: Samsung Np700z4a Bios
    master help me.
    • lapfix
      • Mar 2020
      • 2719
      • my workshop
      Why do you think it's bios issue !!
      There's 3 differents one ( look at the picture ) and try the clean one
      • smallvhin
        • Jul 2015
        • 182
        • philippines
        laptop it's default usb booting.
        installing first part of windows finish and restart.
        after restart.
        same issue again show logo then on and of screen.
        Nike 14 np700z4a model master
        • smallvhin
          • Jul 2015
          • 182
          • philippines
          master its working file.
          problem: Portuguese keyboards/battery not shutting down.
          pls.. fix my bios more thanks Master
            • 20795
            Search for the word $Revision with HxD , the platform ID is FD
            https://www.badcaps.net/forum/showthread.php?t=88206
            • smallvhin
              • Jul 2015
              • 182
              • philippines
              master no luck. try to fix my bios🙏
              • the Benninger
                • Nov 2022
                • 189
                • venezulan
                HI Dudes.. Same Notebook NP700Z4A-SD1BR BackupBios is Blank
                s/n: HNNB9QJC900029A
                MB: NIKE 14 Rev:1.1-5
                BA41-01731A GCE
                THANKS IN ADVACE Click image for larger version
Name:	Captura de pantalla 2024-02-21 115214.png
                • the Benninger
                  • Nov 2022
                  • 189
                  • venezulan
                  I'm so sorry for the mistake on my part, I made a bad choice to place wrongI'm sorry for the mistake on my part, I made a bad choice to place the wrong TSOP model, hope you help me the error is that it does not generate image, it could be the memory integrated in the board, some advice on how to deactivate these integrated memory disabling some power or something of type
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                    09-07-2024, 05:50 AM
                  • TJ65
                    Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
                    by TJ65
                    i made out of two broken Samsung Galaxy Tabpro S one that works partially.
                    The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
                    I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
                    The problem is, that the micom Version doesn't match with the bios version, see picture.
                    How can i update the Micom Version? The Samsung bios update wont work.
                    With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
                    01-09-2025, 01:35 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
