850 G8 did not boot since restore original DMI DATA
  • adom
    • Sep 2021
    • 12
    • Switzerland
    hey i have a problem i wanted to remove a bios password on a 850 G8 now the laptop won't turn on.
    the laptop was still working when i loaded the patch file from *******
    After that I reset the bios setting to factory settings and since I loaded the original dmi data the laptop no longer starts
    • 21473
    Re: 850 G8 did not boot since restore original DMI DATA
    If you want support for that paid software go to their website and ask why it isn`t working,this isn`t their support forum.If you want the members here to help you, for free ,post your original backup and someone might be able to help.
    • adom
      • Sep 2021
      • 12
      • Switzerland
      I published the original backup
      • alfredposadas09
        • Aug 2020
        • 343
        • Philippines
        u should use hp super editor not that one
        • adom
          • Sep 2021
          • 12
          • Switzerland
          When the AC adapter is connected, the CapsLock LED will flash once, then turn off. The display stays black and the fans don't spin at all.
          • Kodza
            • Jun 2016
            • 191
            • South Africa
            I have HP 850 G8 with computrace please help remove
            • mac2sell
              • Aug 2017
              • 64
              • Italy
              Can anyone help me to unlock bios
              elitebook 850 g8?
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                elitebook 850 g8?
                You finally managed more or less to find the right topic, it wasn't that hard was it?
                Become a Badcaps supporter
                Thanks to all supporters.
                • mac2sell
                  • Aug 2017
                  • 64
                  • Italy
                  More or less
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    More or less
                    We'll see, we'll see.
                    Just don't forget in which corner is the button to the search engine.
                    • aledido
                      • May 2023
                      • 8
                      • Alemanha
                      Hello, I would be very grateful to know if I can use these files (367,366 ) on an Hp 850 g8 with the same password problem? Thanks in advance and I wish you all a great day!
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        No, upload your bios backup files here.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12139
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12139
                            can anyone help me to unlock bios
                            elitebook 850 g8?
                            11111111
                            • aledido
                              • May 2023
                              • 8
                              • Alemanha
                              thank you very much for your kindness, here are the two files. I will be very grateful for your help!
                              • aledido
                                • May 2023
                                • 8
                                • Alemanha
                                • alfredposadas09
                                  • Aug 2020
                                  • 343
                                  • Philippines
                                  here is your unlocked file
                                  • aledido
                                    • May 2023
                                    • 8
                                    • Alemanha
                                    Thanks, as soon as I finish the bios recording process, I'll let you know the result!
                                    • aledido
                                      • May 2023
                                      • 8
                                      • Alemanha
                                      now the CapsLock LED and the num lock LED blink about seven times then turn off. The screen is black and the fans do not spin.
                                      it didn't work, I resoldered u367 with the original file. I saved the file you sent me on U366 and recorded it. if you have any solution please let me know, it will be of great help, here are the original backup files again thanks!
                                      • aledido
                                        • May 2023
                                        • 8
                                        • Alemanha
                                        [QUOTE=aledido;1245992]
                                        I re-recorded it again, wait a bit, I think we will succeed!
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                          Acer Extensa EX2540-56BF + PowerCube Original Notebook 15 Specification for Upgrade or Repair
                                          This specification for the Acer Extensa EX2540-56BF + PowerCube Original Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX2540-56BF + PowerCube Original boardview and EX2540-56BF + PowerCube Original schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 08:16 AM
