Hello friends, I have this laptop with a black screen, when turning on the fan turns and turns off after 15 seconds, if I remove the ram memory if there is a ram error code, but when extracting the .bin file from the original eeprom and want write a new one it shows verification error, it is not completely erased, this makes me think that the eeprom is damaged, I already changed the eeprom and wrote successfully, I used the bios dump from the following thread: https://www.badcaps.net/forum/showthread.php?t=95250 but it gives the same failure, if anyone can check my original .bin file, the laptop has a erase Service tag and model sticker, I don't know what model it is exactly. Thanks a lot.
Bios dump Dell 14 VEGAS/TURIS SKL/KBL 15341-1 91N85
Re: Bios dump Dell 14 VEGAS/TURIS SKL/KBL 15341-1 91N85
I already have the model, can someone clean my bios, thanks.
Dell Inspiron 14 3467
Motherboard VEGAS/TURIS SKL/KBL 15341-1 91N85Attached Filesif you find these attachements useful please consider making a small donation to the site
Try and feedback
Your ST : CXCH6P2Attached Filesif you find these attachements useful please consider making a small donation to the site
hello guys could you repair my bios please
service tag : 65909L2
try bios OKAttached Filesif you find these attachements useful please consider making a small donation to the site
Service Tag- 908Z0F2.
Board NO- vegas/turis skl/kbl 15341-1
AMD Graphics.
Problem- No Display.
Plz Need Bios.
Old Bios Attach plz find.
MX25L12805D@SOP16_20250129_172218 Old.rarAttached Filesif you find these attachements useful please consider making a small donation to the site
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Vegas / Turis SKL / KBL 15341-1 91N85
Service Tag
​B7ZQFT2Attached Filesif you find these attachements useful please consider making a small donation to the site
Dell VEGAS/TURIS SKL/KBL 15341-1 91N85
Hello. I need help cleaning this BIOS. The service tag has been erased. Thanks in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
It worked 100%Comment
by aliiashHi
I need to a tested bios file of laptop dell
board number : vegas/turis skl/kbl 15341-1 91n85
this is original file
Channel: BIOS Requests ONLY!
by lapfixHello my friend.
When connected to power supply consumption is 0.09 amp / power button = reach 0.150 amp...than off.
i follow the power up sequence and as i know :
After getting ALL_SYS_PWRGD, the io generate a signal adressed to VRM called VR_ON / VR_EN , this is the VRM enable signal .
If CPU core is ok the VRM chip will generate its power good signal adressed to SP/PCH , this signal is termed = VRM_Power good / VR_RDY .
With this motherboard all is ok until sequence 8a= VR_RDY.
Questions :
1 =... -
by Techtigeri got this Mob need help Veteran's 15341-1/91N85 no liquid damage or corrosion , bord power up but no Video PL4801 VCCGT missing ,no beep or blink code's
Flash BIOS with SMDFlea one but not the EC
(https://www.badcaps.net/forum/showth...hlight=15341-1)
POST#3 and one from
(https://www.laboneinside.com/tag/153...1n85-bios-bin/)
now the Mob shut down after 2 mins fan on full speed blink code Amber 2 white 7 power lab 0.50 drops to 0.30 Num Lock comes after 1mins DRAMRST 1.2V ALL SYS PWERGD 3.3V PLTRST ok
by RofixHi everyone, I wanted to kindly ask you for help, I have a problem with my Dell vegas/turis mlk kbl-r 17841-1 wx2rr PC, it turned off and I was no longer able to turn it back on, I'm checking the various voltages, unfortunately I found the 19 v up to the input components PU4411, PQ4401, thank you all for any advice
by AhariHi all,
I...-
- Loading...
