ASUS ROG GU603ZE clean pass on bios or need bios
  • misha97123
    • Feb 2021
    • 36
    • Qazaqstan
    hello everyone need help with this laptop how to delete password from dump or edit bios from offsite. I am attaching the old dump and dump from t offsite
    https://drive.google.com/file/d/1ETs...ew?usp=sharing
  • misha97123
    • Feb 2021
    • 36
    • Qazaqstan
    Re: ASUS ROG GU603ZE clean pass on bios or need bios
    Old and Offsite dumps
    • misha97123
      • Feb 2021
      • 36
      • Qazaqstan
      I cut the BIOS region from the update, but the offset is B04E30 - 11 284kb, in the old dump region offset size B00000 - 11 264kb.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        Here
        • misha97123
          • Feb 2021
          • 36
          • Qazaqstan
          Originally posted by hoaca388
          Here
          Good, I'll try it next week, but I try to do it myself, I found out that need to remove the scripts from dump and then it will be the right size, thank you man.
          • SIRAJUDIN
            • Apr 2023
            • 5
            • indonesia
            please repair & clear me
            • peste
              • 13924
              • ROMANIA
              read..https://www.badcaps.net/forum/troubl...before-posting
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
