HP Bios for 15-CS3034NB corrupted looking for working one.
  • Dcaub
    • May 2022
    • 6
    • BE
    I have done updates by hp assitant and there was a Bios update.
    The update was done everything seems to be ok but after powering down the laptop it wont start again.
    The laptop is from a daughter of a friend... so i wanted to help to do all the updates for here so he gived me the laptop perfect working... and now i have had to tell that it is not working anymore ...
    The Caps Lock key is flashing 5 times long and 3 times fast .
    So i am almost shure the Bios has been misflashed since it happens after this flash.
    Is there someone that can help me on a working one.
    The mainboard in the laptop : DAG7BLMB8D0 Rev D.
    Model nr laptop HP Pavilion 15-CS3034NB
    I have readout the old bios (the one that is corrupted) and have it attached zipped maybe needed.
    Many thanks and hope someone can help me.
    Thanks.
    Dca
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: HP Bios for 15-CS3034NB corrupted looking for working one.
    Thanks.
    Dca
    You should be a good writer
    Try and give feedback
    New built + Your DMI+Your win serial
    • Dcaub
      • May 2022
      • 6
      • BE
      Thanks for file.
      I have tried the 086AA New.rar you have provided but it is exactly the same issu caps lock LED flashes 5*slow and 3 times fast. Identical like the original bios .
      After the bios update from HP assistant everything was ok. Shutdown the laptop normal way and by first restart the issue is there.
      Is there someting else i can try ?
      Thx
      • zlr8r
        Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
        by zlr8r
        Greetings
        I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
        Serial Number: 5CG3202C16
        Product #/SKU: 739P0AV
        CT Number: PRTUE00WBI30YX
        Description: HP ZBook Firefly 14 inch G10
        BuildID: 23WWWGAZ602#SABU#DABU
        Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
        MAC address not found.
        • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
        10-28-2025, 01:56 PM
      • TylerHyde21
        Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
        by TylerHyde21
        Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
        I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
        I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
        This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
        06-29-2024, 10:38 AM
      • Loli Popu
        DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
        by Loli Popu
        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
        12-13-2024, 08:29 AM
        by Vesko356
        08-11-2023, 03:27 AM
      • Loki_Fido
        Thinkpad X1 Yoga Gen 3 ,How to know if the BIOS is corrupted
        by Loki_Fido
        Hi everyone, hope everyone's having a great day.
        I have a Lenovo Thinkpad X1 Yoga Gen 3 for repair. (20LES3T900)
        I looked in every corner and the laptop seems fine. Its pulling 500mA but no display, no noise, nothing.
        So I assume its a BIOS issue. I downloaded the BIOS with CH341A and opened it on ME Analyser and didn't receive any errors.
        Does this mean the BIOS is fine? making it a hardware issue?
        I downloaded fresh BIIOS from the Lenovo site and used Hex Editor replace the Lenovo's BIOS into my BIOS region. But the file size ended up being...
        03-14-2025, 07:42 PM
