Lenovo L460 LAN issue after BIOS dump flash
  • bestrafer
    • Jun 2020
    • 12
    • Ukraine
    Hello everyone.
    I have L460 Type 20FV (2 X 8MB bios chips) with no boot issue after BIOS update (black screen with restarts, common issue on this model + BIOS update).
    BIOS dump(s) from this post https://www.badcaps.net/forum/showpo...7&postcount=27 makes the laptop boot absolutely fine, no delays, etc..
    But there is an exclamation mark in the device manager for the LAN card right after fresh OS installation - LAN naturally doesn't work. I saw requests like "BIOS: fix LAN" on other sites.
    Could someone point on a direction where to read and what should be fixed in the BIOS dump(s) pointed above?
    I tried to load outimage(1).bin into "CSME System Tools v11 r46", but it gives me a lot of errors. There is a "gbe region" section in "Flash Image Tool" to provide a clean LAN region - must be there?
    Likely, doing something totally wrong.
    Thank you
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: Lenovo L460 LAN issue after BIOS dump flash
    Originally posted by bestrafer
    Hello everyone.
    Thank you
    Upload your Original Backup.
    all donations are welcome,
    • bestrafer
      • Jun 2020
      • 12
      • Ukraine
      Unfortunately, I don't have original dumps.
      I used the dump from the mentioned post (2 files). I'm attaching a single merged dump to simplify further investigation in Intel tools. It works for me, but LAN adapter fails to start (code 10) in Device Manager.
      I suspect GBE region should be cleaned up, but don't know where to grab clean GBE region.
        • 22097
        Is there a sticker on the motherboard with the MAC address on it
        • Mr.Nobody
          Retired
          • Apr 2022
          • 73
          Hi!
          I have the same problem in this thread...not resolved so far...
          https://www.badcaps.net/forum/showpo...8&postcount=37
          Maybe we can find a solution for my laptop too...
          Thanks!
          • bestrafer
            • Jun 2020
            • 12
            • Ukraine
            I can't see any (
            Originally posted by Mr.Nobody
            Hi!
            Where is sticker with MAC on the board?
            There are requests to fix LAN, but it looks like original dump is required - just google for L460 on vinafix com
            • Mr.Nobody
              Retired
              • Apr 2022
              • 73
              I can't see any (
              The sticker is under RAM1.
              Cheers!
              • bestrafer
                • Jun 2020
                • 12
                • Ukraine
                Ok, assuming we have original MAC address, what could I try to fix the LAN issue?
                Edit GBE_region.bin and replace whatever MAC in it with the machine's original one, then rebuild bios?
                • Mr.Nobody
                  Retired
                  • Apr 2022
                  • 73
                  That will be amazing if in the files from post #27 we change only the MAC address and the LAN will work...obviously in
                  outimage(1).bin...
                  I have two laptops with the same LAN problem, both flashed with files from post #27.
                  Cheers!
                  • bestrafer
                    • Jun 2020
                    • 12
                    • Ukraine
                    For some reason windows shows it fails to start LAN i219-LM, while it's supposed to be i219-V(2) version of the NIC.
                    Anyone knows how to fix GBE region and where to grab "clean" GBE.bin?
                    • Mr.Nobody
                      Retired
                      • Apr 2022
                      • 73
                      Hi everyone!
                      It seems I can't fix this problem although I tried everything to fix it.
                      So, decompiled the bios.bin (concatenated the two eeprom content) with Flash Image Tool - No errors, get the GBE Region.bin from Decomp folder (renamed to gbe.bin for process). After that changed the MAC with two tools, the older nvmmac gbe.bin c8:5b:76:bf:15:ed and the newer nvm gbe.bin setmac c8:5b:76:bf:15:ed. After that checked the CRC to be correct with nvmcheck gbe.bin and nvm gbe.bin dump. After that rename back to GBE Region.bin, put it back in Decomp folder and rebuild the bios.
                      Nothing works for LAN. Has a Code 10 in Windows. Checked the controller and it's recognized correctly WGI219LM.
                      The laptop boots fast and everything is working except LAN.
                      That's it for now ...
                      Cheers!
                      • J_PH
                        • Dec 2022
                        • 37
                        • Chile
                        Please, check this.
                        I kept the BIOS Region from the dump that works, but updated the ME Region to the original version of your dump.
                        • Mr.Nobody
                          Retired
                          • Apr 2022
                          • 73
                          Originally posted by J_PH
                          Please, check this.
                          Thank you for the dump but it's not working...
                          After pressing the power button the power led blinks a few times (sometime 4 sometime 7 or 8 times) and after that stays on for about 20 - 25 seconds and shut down. No picture at all.
                          Thank you for your help.
                          Cheers!
                          • J_PH
                            • Dec 2022
                            • 37
                            • Chile
                            Please, check this.
                            I updated the ME and cleared the ME Region
                            • J_PH
                              • Dec 2022
                              • 37
                              • Chile
                              Hello everyone, I need a little help on the following.
                              I am trying to solve the problem of the user Mr.Nobody.
                              He has a dump (obtained on this forum) that works correctly, except for the LAN adapter.
                              Unfortunately it does not have the original dump.
                              1.- Is it possible that having incorrect DMI information is causing this problem?
                              2.- I have tried to get the BIOS region from the Lenovo package but the extracted file (it is not a TDK) is less than the size of the BIOS Region.
                              Attached dump that works without LAN and Lenovo upgrade package
                              L460 Laptop (ThinkPad) - Type 20FV
                              S/N PF0GJNZ7
                              • lfb
                                • Mar 2018
                                • 6
                                • Norway
                                Both dumps have a ME 11 Corporate LP with Power Down Mitigation while the original dump from the threadowner and the updates from Lenovo have a NPDM ME.
                                The solution for the threadowner was the ME config from his own dump which had a different port for the GbePCIePortSelect- see attached pic (and a repaired bios region).
                                The mentioned differences may be OK if there was a change in mainboard config at a point, but since there's a wrong ME version, OEM ID removed from ME config that's clearly a file that's been fiddled with already..
                                Try the attached firmware, I took the FD and ME from threadowners cleaned image together with your 'own' GbE and bios region.
                                (GbE should have the correct MAC since it gets written into ME when initializing ME for the first time, so I don't know what might happen when ME is initialized with a wrong/different MAC address.)
                                EDIT: Seems there were some more L460 stuck in bios updates at the same point. Hope it's allowed to link to another forum, here's more detailed what was done: https://winraid.level1techs.com/t/le...mp-flash/92774
                                • Mr.Nobody
                                  Retired
                                  • Apr 2022
                                  • 73
                                  Hi lfb!
                                  Thanks for the dump, works perfectly !
                                  At first boot complains for wifi card not genuine or something like that, i wasn't there and I caught just one second of the error... but after restarting without wifi card and load defaults F9 then putting back the wifi card, the laptop is working fine.
                                  Thank you for your help and time.
                                  Cheers!
                                  P.S. Working fine with any MAC...On the sticker I have C8:5B:76:C8:E1:9F and the BIOS shows 50:7B:9D:EF:2C:02
                                  • lfb
                                    • Mar 2018
                                    • 6
                                    • Norway
                                    Thanks for the feedback!
                                    I wonder- did you really use the dump in 2.zip from #16 here or the dump from the winraid thread?
                                    • Mr.Nobody
                                      Retired
                                      • Apr 2022
                                      • 73
                                      Hi !
                                      I use the 1_L460_original_rec_nvr_me_2files.zip dumps from winraid.
                                      • lfb
                                        • Mar 2018
                                        • 6
                                        • Norway
                                        ... I use the 1_L460_original_rec_nvr_me_2files.zip dumps from winraid. ..
                                        OK, then it's consistent, that's simply the MAC from the GbE as it's supposed to be.
                                        You can replace the MAC in GbE (both at 0x1000 and 0x2000) with your own MAC from the sticker. There's a checksum in the GbE but afaik it doesn't need to be corrected for normal use.
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          Today, 04:04 PM
                                        • Syph1979
                                          PS5 EDM-031 1216A BIOS Issue
                                          by Syph1979
                                          Hi all. First post here, so I hope I'm getting this right and operating in the spirit of things here.
                                          I've been working on consoles for a while now. Always learning and trying new repairs, but I have one that has been stumped and I wondered if anyone with more experience could help?
                                          I picked up a PS5 from eBay recently. It was described as not having the disc drive, but it was also a no power unit. On testing it was clearly an issue with the supply (no 12v), so I replaced that and then when I inserted the power lead, I got 3 beeps. So far, seems all related. As I was...
                                          09-25-2025, 05:48 AM
                                        • TyMercer
                                          Can I flash a working BIOS from one computer to another of the same make, model, etc?
                                          by TyMercer
                                          Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                                          Yesterday, 09:39 PM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
