Lenovo L460 LAN issue after BIOS dump flash
  • Mr.Nobody
    Retired
    • Apr 2022
    • 73
    Re: Lenovo L460 LAN issue after BIOS dump flash
    Originally posted by lfb
    OK, then it's consistent, that's simply the MAC from the GbE as it's supposed to be.
    You can replace the MAC in GbE (both at 0x1000 and 0x2000) with your own MAC from the sticker. There's a checksum in the GbE but afaik it doesn't need to be corrected for normal use.
    OK, i will change if necessary with nvm *.bin setmac or nvmac *.bin xx.xx.xx.xx.xx.xx and then even the checksum will be corrected.
    Thank you.
    Cheers!
    • lfb
      • Mar 2018
      • 6
      • Norway
      Are those nvm, nvmcheck nvmmac programs windows versions? Could you give me a hint what to search?
      I searched a while but could only find incompatible or older versions?
      Thanks in advance!
      • Mr.Nobody
        Retired
        • Apr 2022
        • 73
        Thanks in advance!
        No they are Linux programs. I use them on Ubuntu 20.
        You can find them here :
        https://notabug.org/osboot/nvmutil.git
        https://notabug.org/osboot/nvmutils.git
        and a little help here:
        https://libreboot.org/docs/install/nvmutil.html
        Cheers!
        • lfb
          • Mar 2018
          • 6
          • Norway
          Thank you!
          • Mr.Nobody
            Retired
            • Apr 2022
            • 73
            Thank you!
            You're welcome!
            That's the role of a forum : sharing !
            Knowledge, software, whatever helps others...
            Cheers!
            • tomalamix
              • Nov 2020
              • 32
              • Portugal
              #26
              Originally posted by Mr.Nobody
              You're welcome!
              Cheers!
              Hy everyone,
              Is there a specific software to do a BIOS backup before trying to mess up with it?
              I would like to do some testing on the file
              thanks
              • Mr.Nobody
                Retired
                • Apr 2022
                • 73
                #27
                Originally posted by tomalamix
                Hy everyone,
                thanks
                Hi!
                Read here : https://www.badcaps.net/forum/showthread.php?t=103526.
                There are several programmers and software for them.
                And as method u can use a clip for onboard programming or soldering iron or hot air for de-solder the BIOS chip, read it first (for backup) then erase and program the modified version.
                Cheers!
                • laerts63
                  • Jul 2023
                  • Russian Federation
                  #28
                  hello guys!
                  I dug for a long time and figured out bios thinkpad l460.
                  I have such a situation: the bios chip is out of order. Nothing from all the forums brought any results. after numerous searches, I assembled the uefi assembly to make it work.
                  1. the problem is the lack of startup at all (solution on the bios chip when flashing "status reg" qe=1)
                  2. I will not comment on intel ME, I found about 30 working versions of 11.x.xx.xxxx I think there are a lot more of them.
                  3.!!!! wired lan not work error: what I just didn't try in the available bios versions. solution: flash image tool v11 >>> network and connectivity>>>wired lan configuration>>>Gbe PCIe Port Select>>>Port5 to Port4. some may do the opposite.
                  please use the solution
                  gbe region contains only the address and model of the network card and its id.
                  4. encountered system friezes: freezes are short, barely noticeable. solution - me 11.8.83.3874
                  5. bonus found where the lenovo logo is hiding)))
                  • cr4zychriss
                    by cr4zychriss
                    • Rebrand: PC Specialist
                    Today, 04:04 PM
                  • Syph1979
                    PS5 EDM-031 1216A BIOS Issue
                    by Syph1979
                    Hi all. First post here, so I hope I'm getting this right and operating in the spirit of things here.
                    I've been working on consoles for a while now. Always learning and trying new repairs, but I have one that has been stumped and I wondered if anyone with more experience could help?
                    I picked up a PS5 from eBay recently. It was described as not having the disc drive, but it was also a no power unit. On testing it was clearly an issue with the supply (no 12v), so I replaced that and then when I inserted the power lead, I got 3 beeps. So far, seems all related. As I was...
                    09-25-2025, 05:48 AM
                  • TyMercer
                    Can I flash a working BIOS from one computer to another of the same make, model, etc?
                    by TyMercer
                    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                    Yesterday, 09:39 PM
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
