latitude 3420 - 25rh256cxiq chip problem
  • layad
    • Nov 2011
    • 244
    hi there , i have dell latitude 3420 , st: 3mpysl3
    which have 25rh256cxiq chip, couldnt read the chip, every time i read it , gives me differnt file content, im using SiberiaProg CH341A v1.45 software, is there anyway to fix the dump file i read, and remove the password so i can write it to an other chip i have (25r256jven)? i uploaded 2 files i read in diffrent way, i dont know which one can be fixed
    • 21663
    Re: latitude 3420 - 25rh256cxiq chip problem
    https://www.badcaps.net/forum/showpo...8&postcount=80
    https://www.badcaps.net/forum/showpo...4&postcount=81
    NeoProgrammer software version 2.2.0.10 supports the XM25QH256B chip.The 3.3V voltage mod might help as well if you have the ch341a Black PCB version
    https://www.badcaps.net/forum/showthread.php?t=103526 -> 1.1.1.6. CH341A
    • layad
      • Nov 2011
      • 244
      thank you but the chip is 25Rh256cxiq
      not XM25QH256B
        • 21663
        not XM25QH256B
        Here`s a quote from the post in the first link i posted,which i don`t think you read
        " i have XMC 25RH256CX ic 3.3v , i have done dumps using XM25QW256C [3.3V] , W25Q256BV [3.3V] and MX25L25635E [3.3V] , all files compared and they are same. "
        He had the same 25Rh256cxiq chip as you,and he solved it by selecting the XM25QH256B chip and doing the voltage mod. When a bios chip is not supported by your programmer you can choose another chip thats the same size and voltage , with some programmers,the TL866II for example,you would have to untick the setiing for check-ID ,as you`re tring to read a chip with a different ID ,and also untick the verify setting.There is no programmer that supports every single chip ever made.
        • layad
          • Nov 2011
          • 244
          thank you i could mange to get two dumps which are the same , how to make sure that these dumps are fine so i can earse the chip? anyone might help me to remove the password pls?
          • jagiro84
            • Jan 2020
            • 41
            • Netherlands
            Oh wow didn't know this, learned something
            I am in similar situation, I have the tl866a programmeert and I need to program winbond 25r256jven chip, should I just select any 256 and uncheck check ID box? Will it be no problem for the laptop?
              • 21663
              the TL866a and CS only support chips up to 128MB .
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • DynaxSC
                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                by DynaxSC
                Hi
                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                08-04-2025, 12:20 PM
              • CapThatBrass
                Dell Latitude 3420 - Locating the BIOS Chip
                by CapThatBrass
                I'm trying to search for the BIOS chip on a Dell Latitude 3420 that I'm working on (faulty BIOS flash), but I'm struggling to find the exact location.
                There's a Winbond 25R256JVEN chip situated on the far left side of the laptop, in close proximity to the RAM modules. I've got to heat the chip up and remove it to inspect any data stored on the chip but would rather know if this is the BIOS chip or has some other function.
                Any guidance would be great.
                Thanks!
                05-24-2022, 11:37 AM
              • pengamat_hebat
                Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
                by pengamat_hebat
                I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
                Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
                However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
                I also tried applying 3.3V to pin 3, but it still didn't work.
                I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
                03-25-2025, 04:13 AM
                How to add chip support to NeoProgrammer software for the CH341A Programmer
                by SMDFlea
                Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                and once you do find them there`s a few crucial steps missing.
                Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                After adding the chip save the xml file and copy it to the root directory of the...
                05-26-2024, 07:15 AM
