HSW131-t bios
  • comifrancesco_f
    • Oct 2021
    • 9
    • Italy
    HSW131-t bios
    Help pls, need bios 4 a toshiba kyra, unknow model, mobo "HSW131-t".
    Found exactly the same mobo in other laptop with a google search, already tried to clean the ME region. Here is the backup of the original
  • peste
    • 13430
    • ROMANIA
    Re: HSW131-t bios
    try..
    • Lexsmash85
      Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
      by Lexsmash85
      Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
      Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
      USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
      08-06-2025, 03:41 AM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • AppleLover123
      Acer Aspire A315-56-37qb mobo fried after programmed bios
      by AppleLover123
      Hello guys,
      i've got this Laptop from ebay the bios was bricked. I bought it a few weeks ago and flashed it with
      a CH341A Programmer first (Bios.bin attached) all that went good my bios worked and it booted up afterwards.
      Now i used it and wanted more memory so i went from a 4 GB 1Rx16 to a 16GB 1Rx8 .
      But it wont boot up with the new ram stick that i checked before in another laptop then i thought it was a good idea to flash the bios again
      with the same .bin so i dissasembled the laptop and took out the mobo and flashed the bios again (same way i did it before)...
      11-09-2024, 05:42 AM
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
