HP EliteBook 640 G9 Bios password
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ---------------------------------------------------------------------------------------------------------------------------------------------------------------- -
At 1st boot press F10 and RESET BIOS to factory defaults
use HP BCU to fill dmi infoAttached FilesComment
please help me remove password for my hp elitebook 640 g9. thank you in advance,
SN# 5CD225C3RK
ProdID 6c0z1ut#ABA
hp Elitebook 640 G9
First boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults
Use BCU here's your DMI info:
Serial Number: 5CD225C3RK
Product Number: 6C0Z1UT#ABA
CT Number: PQNNL018JGN0UG
Description: HP EliteBook 640 14 inch G9
build_id: 22WWRTCT601#SABA#DABA
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAdpdqfPguhKhkjhk8mEmGn7nVnwpDpFpVpppqqjqz.47
MAC Address: 84-69-93-4D-DA-C5Attached FilesComment
here is your unlocked file hope it worksAttached FilesComment
SN# 5CD3221G9S
ProdID 7P955PC#UUF
hp Elitebook 640 G9
650 g9 12th pass please unipass
SN 5CD34316C5
ID 4D174AVAttached FilesComment
First boot press F10 reset bios to factory defaults & Restart, 2nd boot reset security settings to defaults.
search here bios config utility in forum in case you don' know.
Use BCU to fill these DMI INFO:
Serial Number: 5CD34316C5
Product Number: 4D174AV
CT Number: PPUZR108JIQ00E
Description: HP EliteBook 650 15.6 inch G
build_id: 22WWRTDZ602#SABF#DABF
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawcAeMfPguhKhkjhk8mEmVn7nVpDpTpnpqprqjqz.eQ
MAC Address: 30-F6-EF-93-DF-B9Attached FilesComment
do not touch the EC.
MAC Address: 84-69-93-4D-DA-C5Comment
Hi guys this pw locked tried with RCUnlocker no good, same output..
HP EliteBook 640 g9, SN#5CD2527PGJ
DA0X8SMB8H2 REV: HAttached FilesComment
hello can you please help me remove bios password..
SN :5CD3221GFQ
PRODID : 7P955PC#UUF
MODEL : HP ELITEBOOK 640 G9Comment
Try flashing this modified bios..
First boot reset to factory defaults
Second boot reset security settingsComment
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by BlackVisorRedmiBook Pro 1542022 6800H
SKU: TM2113-39463
Model Number: RMA2204-AB
CMIIT ID: 2022AP1835
SN: 39463/22WD01355
BIOS version: RMARB5B0P1010 20230628
1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...-
01-14-2024, 06:35 AM -
- Loading...
