Lenovo t460p bios password unlock
  • 50jaker
    • Apr 2020
    • 19
    • Spain
    Hello, good, I need someone to unlock this bios for me, I have tried the AUTOPATCHER that is published in the forum and no luck now I have a problem
    and it is that when I go back to program the chip the original bios I get 5 short beeps and that sequence of sounds is repeated again.
    I leave you the original bios and see if someone can help me.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11668
    Re: Lenovo t460p bios password unlock
    Check it by ME-Analyzer , clear ME that file and then run Autopath.
    • 50jaker
      • Apr 2020
      • 19
      • Spain
      Okey im gonna try to clear ME, I will keep you informed of the results
      Thnks
      • 50jaker
        • Apr 2020
        • 19
        • Spain
        I cleared the ME from the bios but when i drag the new BIOS with the new ME on it, the Autopatcher close the window without generating the Patched file.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11668
          The operation of clearing your ME region is wrong.
          • 50jaker
            • Apr 2020
            • 19
            • Spain
            i see, the SKU is wrong, i needed to find a INTEL ME with Corporate SKU
            • hoaca388
              Badcaps
              • Jan 2022
              • 11668
              https://www.badcaps.net/forum/showpo...41&postcount=3
              • Markus1741
                • Sep 2020
                • 843
                • N/A
                Try this patch from your original file I swapped something out...
                • 50jaker
                  • Apr 2020
                  • 19
                  • Spain
                  I'm going to try both bios, I hope I'm lucky thank you very much for helping me
                  • 50jaker
                    • Apr 2020
                    • 19
                    • Spain
                    Neither of the two BIOSes have worked for me, none of them turn on the screen and it does not make any beeps, only the power light stays on.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11668
                      Check your procedure again, replace the a new bios chip if necessary, the file T460P_type20FX.bin has been refreshed.
                      • 50jaker
                        • Apr 2020
                        • 19
                        • Spain
                        I have tried again and nothing, and the chip is fine since I have unsoldered it and it reads the data correctly and writes it well, the only bios that at least reacts is the original one and it gives me 5 beeps as if the motherboard were dead but Actually, the video worked perfectly and it started with the locked bios, but now that I have tried to go back to the locked bios, when i turn it on it only gives me 5 beeps.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11668
                          Are there any components around the bios chip that are lost or displaced when removing the chip?
                          • 50jaker
                            • Apr 2020
                            • 19
                            • Spain
                            No, all the components are in their place, always when desoldering a component such as a chip, I protect the area where I am going to solder with electrical tape. i have photos of the chip
                            update: old bios when i put on the motherboard It sounded an error message of 5 beeps, pause, 5 beeps
                            • Markus1741
                              • Sep 2020
                              • 843
                              • N/A
                              Hello but you already know that your original BIOS that you provide in #1 is corrupted?
                              • 50jaker
                                • Apr 2020
                                • 19
                                • Spain
                                Seriously? I didn't know, it may be that when reading with the programmer something happened since I did it with the soic clip.
                                What can I do now since I don't have any copy of that bios.
                                because I downloaded the uefitool and i checked all copies i did before the write and all the copies I made are just as corrupt
                                • Markus1741
                                  • Sep 2020
                                  • 843
                                  • N/A
                                  You can try it happened to me with a Lenovo X250, I didn't have the original BIOS anymore, I did it with someone else.
                                  It is important that the ME region is cleaned worked for me.
                                  https://www.badcaps.net/forum/showpo...postcount=2073
                                  • 50jaker
                                    • Apr 2020
                                    • 19
                                    • Spain
                                    What did you do to recover it, did you look for someone who had the same bios without a password but with a clean ME?
                                    • Markus1741
                                      • Sep 2020
                                      • 843
                                      • N/A
                                      To dispel a myth, the password for the LENOVO BIOS is not stored in the BIOS
                                      CHIP, anyone who makes a request here and uploads a LENOVO BIOS with a
                                      password - all these BIOS CHIPs do not contain any password.
                                      Not so with HP or Dell.
                                      You won't have many other options either if you don't have a working original
                                      BIOS, try something else.
                                      Try installing the ME Clean File first and see if it works, then apply the patch.
                                      • 50jaker
                                        • Apr 2020
                                        • 19
                                        • Spain
                                        Okey do you have the same image for W25Q128FV or is safe using that image you shared with that chip?
                                        update: when i put the clean ME image in the chip that you shared, the laptop turn on the led of the keyboard and the power led and shutdown and then turn on again but with out video like a loop boot
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • RMDUiFT
                                          Should I buy a Lenovo Thinkpad E495 with bios password?
                                          by RMDUiFT
                                          Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                          I have a few questions:
                                          • If I would buy this laptop and have
                                          08-25-2024, 09:00 AM
                                        • darknwo
                                          Bios password Lenovo Legion 16IRX8H
                                          by darknwo
                                          Hi, can someone help me please with the removal of the bios password of this dump.
                                          Someone desoldered the bios chip, tried several "methods" but with no luck, and he gave me the dump to try to search some help.
                                          For now he deleted more things and bios password is gone but laptop doesn't show serial, model etc.
                                          Also, I updated bios to latest version, when he will write the dump again without password, it should be better to put back the old version that was orignally or doesn't matter? Because from what I've read this laptop has 3 bios chips, don't know if has...
                                          10-05-2024, 10:40 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
