Thinkpad L480 Bios repair
  • figuevin
    • Dec 2020
    • colombia
    #41
    Cordial greetings.
    I have a doubt, in the lenovo L480, there are two bios chips that are in U0901 and u4502. Both are reprogrammed or only the U0901? What function has the U4502?
    Thank you very much for your help​
    • Maxpys
      • Jan 2023
      • Poland
      #42
      Hi, is there a option to help me with corupted bios. No boot, no screen just power light. It dose not even beep when I remove ram. Thank you
      • peste
        • 13924
        • ROMANIA
        #43
        read the rules..https://www.badcaps.net/forum/troubl...before-posting
        post the S/N, the full name and model of the laptop,the motherboard model, etc.
        • peste
          • 13924
          • ROMANIA
          #44
          Originally posted by ajaysharma
          Hi Team, i need L480 Patched file please send ..NM-B461
          respect the rules.. read the post above..
          • Schoker
            • Jul 2024
            Hallo.
            Sie ich brauche Hilfe.
            Meinen Lenovo ThinkPad L480 Typ 20LS-0017GE S/N: PF-1L2WN6 mit Schwarzcrean.
            Powerknopf Capslock und Esq Tasten leuchten. Können Sie mir Bios Bin Datei Vielen Dank
            Hello.
            I need help.
            My Lenovo ThinkPad L480 Type 20LS-0017GE S/N: PF-1L2WN6 with black screen.
            Power button Capslock and Esq keys light up. Can you send me the Bios Bin file? Thank you very much​
            in English please..
            • merlin2004
              • Oct 2020
              • 6
              • Magyarország
              #46
              Hello Sir!
              My problem is as follows. Lenovo L480 20LT-S43L00 S/N:PF-25JM3Y no picture and esc and capslock are lit. I would like help with this. I am sending the wrong file.
              Thanks​
              • Markus1741
                • Sep 2020
                • 983
                • N/A
                #47
                Hello try this file Good luck
                • merlin2004
                  • Oct 2020
                  • 6
                  • Magyarország
                  #48
                  Hello Markus 1741!
                  Thank you for your help.
                  Unfortunately, it doesn't work. The truth is that bitlocker is on.
                  • jackx
                    • May 2020
                    • 222
                    • casa1
                    #49
                    Lenovo L480 EL480 EL580 NM-B461 REV. 1.0
                    corrupted bios
                    scratsh caisse no serieal
                    • volinakis
                      • Jan 2021
                      • 2877
                      • N/A
                      #50
                      Originally posted by merlin2004
                      Hello Sir!
                      Thanks​
                      try
                      • jackx
                        • May 2020
                        • 222
                        • casa1
                        #51
                        corrupted bios
                        VOLTAGE it is normal
                        sn PF-1NHEFB
                        20LT-S2V300
                        • d0gan
                          • Feb 2020
                          • 7
                          • Denmark
                          #52
                          Lenovo Thinkpad L480 - Type 20LS-001AMX
                          S/N: PF-19H7LV
                          Motherboard: EL480/EL580 NM-B461 Rev: 1.0
                          Black screen, caps lock and ESC lights - keboard fading light on/off.
                          Corrupted BIOS. Any help please.
                          • volinakis
                            • Jan 2021
                            • 2877
                            • N/A
                            #53
                            S/N: PF-19H7LV
                            you have clean_ME bios - try it 1st, if doesn't work try r0quj11w.bin, is extracted from bios update, same version as yours but you'll have to write your DMI with LMU.
                            • salawayon
                              • Nov 2012
                              • 578
                              • philippines
                              #54
                              no display issue on my attached bios file. tried other files, it works but with very noisy or static sound at boot up.
                              SN: PF-1GW9LR
                              TYPE: 20LT
                              thanks
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12441
                                #55
                                SN: PF-1GW9LR
                                TYPE: 20LT
                                thanks
                                L480 Laptops (ThinkPad) - Type 20LT
                                • salawayon
                                  • Nov 2012
                                  • 578
                                  • philippines
                                  #56
                                  working but the static noise still present. maybe it's a hardware issue already.. thank you..
                                  • d0gan
                                    • Feb 2020
                                    • 7
                                    • Denmark
                                    #57
                                    Hi Volinakis
                                    Thank you for the files. Unfortunately it is still the same with both files. When I plug in the charger the charging indicator lights up orange but then after a couple of seconds it turns off and then restart charging. I can see on the AMP meter, that it takes 20V and up to 2 A but cycles/loops/restarts. Nothing on the screen. Keyboard still fading and ESC and Caps lock lights up. Any suggestions?
                                  • d0gan
                                    • Feb 2020
                                    • 7
                                    • Denmark
                                    #58
                                    Sorry if I have not made myself clear. My reply was in terms of another/different bios file that could help get it work. Could it be the other bios? under 1mb? Not a specific hardware question - but I'll move it if you want me too.
                                    • merlin2004
                                      • Oct 2020
                                      • 6
                                      • Magyarország
                                      #59
                                      Hello
                                      I received a black screen. The bin file I received works. It only accepts bitlocker images. Unfortunately, I don't have a Microsoft account. I don't have the option to restore the laptop. Thank you in advance for your help.
                                      #47 Markus1741, volinakis #50 Thank you for your help
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1375
                                        • France
                                        #60
                                        made a windows usb key and reinstalled it.
                                        bitlocker is not a problem unless you want to recover information on the disk
                                        • to5it0
                                          by to5it0
                                          10-24-2025, 01:35 AM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • MaxonDomkrat
                                          Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                          by MaxonDomkrat
                                          Hi everyone.
                                          I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                          07-30-2025, 01:27 PM
                                          Lenovo ThinkPad L480 Notebook L Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad L480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L480 boardview and L480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 03:30 PM
                                          09-06-2024, 03:21 PM
