Asus X550VX R510V Bios
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • grimacelord
    by grimacelord
    07-10-2025, 02:52 PM
  • TyMercer
    Can I flash a working BIOS from one computer to another of the same make, model, etc?
    by TyMercer
    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
    11-13-2025, 09:39 PM
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
  • rayshine03121408
    I Need Working BIOS for ASUS E410MA R7.1
    by rayshine03121408
    Good Day Masters! Anyone have working bios for ASUS E410MA? i tried reading the BIOS Chip and the programmer cant detect it i think the bios chip is dead... i already tried 2 programmer but same still cant detect the chip. Thanks in Advance
    Model: ASUS E410MA-TB.CL464BK
    SN: N8N0CX06E199324
    BoardModel: E410MA R7.1
    08-26-2025, 05:36 AM
