Dell E5440 no ldo 3v5v,
  • Tend0
    E.E.C.S
    • Oct 2021
    • 92
    • Burkina Faso
    Hello everyone!
    I have a Dell Latitude E5440 on bench that is completely dead, no led, no other activity like there is no power adapter connected.
    The power_jack_in has voltage 19,5V, the PL4 has 19,5 in both sides and the PQ 4 has 19,5 Voltages and gate the pin 4 has 9,37v.
    Main power rail +PWR_SRC_AC had 19,5v in PL400 but on +PWR_SRC i have only 0,50v on pl401
    no ldo only 0,5v Come on VIN (12pin) TPS51125 PU51
    +PWR_SRC and +DC1_PWR_SRC voltage IS 0,5v or it must be 19,5v what wrong?
    Any advice?
    Thank you advance!
    schematic:
    https://drive.google.com/open?id=1Qh...QwMB5GlHZQ2bN6
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell E5440 no ldo 3v5v,
    +PWR_SRC should be 13V approx on this platform. Check resistance on PQ400/404/406. Often PQ400 becomes leaky on this mb blocking the voltage on PL401. The resistance should be measured on 200K or higher.
    • Tend0
      E.E.C.S
      • Oct 2021
      • 92
      • Burkina Faso
      PQ400 pin4 =60k, pin 1.2.3=216k, pin5=60k
      PQ404 pin4 =190k, pin1.2.3=47k, pin5=250k
      PQ406 pin4 =60k, pin 1.2.3=0k, pin5=250k
      all mesure are took with black prob of multimeter to ground and red prob to each point on MOSFET
      multimeter IS UT890c, resistor calibre:600k
      thanks
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Mosfet resistance is not checked this way.
        need to measure it between mosfet pins like
        01.Between Source(Pin 1-2-3) to Gate(Pin4)
        02.Between Source to Drain(Pin 5-6-7-8)
        03.Between Gate to Drain.
        Measure resistance of listed mosfet this way and report back.
        • Tend0
          E.E.C.S
          • Oct 2021
          • 92
          • Burkina Faso
          ok sir thanks
          *PQ400: 01.Source(Pin 1-2-3) to Gate(Pin4) = 163k
          02.Source to Drain(Pin 5-6-7-8) = 60k
          03.Gate to Drain = 237k
          *PQ404: 01.Source(Pin 1-2-3) to Gate(Pin4) = 83k
          02.Source to Drain(Pin 5-6-7-8) = 329k
          03.Gate to Drain = 406k
          *PQ406: 01.Source(Pin 1-2-3) to Gate(Pin4) = 24k
          02.Source to Drain(Pin 5-6-7-8) = 34k
          03.Gate to Drain = 121k
          thanks
          • mon2
            • Dec 2019
            • 14239
            Source - Drain resistance is too low.
            Can you confirm the voltage to ground of the following on PQ400 ?
            Source (1-2-3) ; select any pin
            gate (4)
            Drain (5-6-7-8) ; select any pin
            Likely this mosfet is defective but best to check the voltages first and next remove this mosfet and check the resistance again when the part is OFF the logic board.
            Also the above readings are low.
            • Tend0
              E.E.C.S
              • Oct 2021
              • 92
              • Burkina Faso
              the voltage to ground on
              *PQ400
              Source (1-2-3) =19v
              gate (4)=19
              Drain (5-6-7-8)=19,54
              but in in
              *PQ404 i have:
              Source (1-2-3) =0,5v
              gate (4)=1,03v
              Drain (5-6-7-8)=19v
              i think there is probleme
              *PQ406
              Source (1-2-3) =0v
              gate (4)=0,47
              Drain (5-6-7-8)=0,5
              • mon2
                • Dec 2019
                • 14239
                *PQ400
                Source (1-2-3) =19v
                gate (4)=19
                See attached.
                PQ400 = P-channel mosfet.
                So this means that the GATE pin #4 must be a LOWER voltage than what it is passing between source / drain pins to ENABLE.
                In your case, the voltage on the gate pin is the same as the source / drain pins which means this mosfet is leaking.
                Remove this mosfet and replace with another - not super critical but share the part number of what you may consider as a replacement. It MUST be the same size, it MUST be a P-channel mosfet.
                • Tend0
                  E.E.C.S
                  • Oct 2021
                  • 92
                  • Burkina Faso
                  I removed it and replaced it by 74q3 mosfet
                  and voltage on gate IS 18v and the voltage on PL401 IS recover
                  • Tend0
                    E.E.C.S
                    • Oct 2021
                    • 92
                    • Burkina Faso
                    thank everyone problème was solve After replace PQ400 the pl401 voltage recover and pc charge and turn on
                    best regard !!!
                    very happy
                    • mon2
                      • Dec 2019
                      • 14239
                      Good work! Glad that you updated the thread for future readers.
                      The troubleshooting is from the above sticky by @Piernov on how charging circuits work.
                      https://www.badcaps.net/forum/showthread.php?t=90356
                      • Tend0
                        E.E.C.S
                        • Oct 2021
                        • 92
                        • Burkina Faso
                        thanks so much
                        link will be very useful for me
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          best regard !!!
                          very happy
                          I knew it from the beginning. See my post#2
                          • Tend0
                            E.E.C.S
                            • Oct 2021
                            • 92
                            • Burkina Faso
                            yes effectively I really appreciate your way of making me understand the process to find faulty componement in resistor mode I learned a lot and appreciate the way that the members are determinate for helping
                            you are best
                            • Tend0
                              E.E.C.S
                              • Oct 2021
                              • 92
                              • Burkina Faso
                              Hello team, the PC that I replaced the pq401 came back with the same problem he told me that it happened overnight after diagnosis actually I find the same symptoms I have again I replaced the pqet nothing no voltage at pl401. i need your help for the rest thank you?
                              • mon2
                                • Dec 2019
                                • 14239
                                Measure the voltage to ground of the mosfet at PQ400.
                                Meter in 30v or higher scale.
                                Red probe to source (1-2-3) pin.
                                Black probe to ground.
                                Repeat for gate (4). Repeat for drain (5-6-7-8).
                                What is the voltage of PU402,
                                pin #5 (ACOK) ?
                                Pin #20 (VCC) ?
                                Pin #16 (REGN) ?
                                Post each measurement.
                                • Tend0
                                  E.E.C.S
                                  • Oct 2021
                                  • 92
                                  • Burkina Faso
                                  DC IN = 19,96
                                  PQ400 voltage: Source = 19,48v ; Drain = 19,96v; Gate = 11,50v
                                  PU402 voltage :
                                  pin #5 (ACOK) =00.00v
                                  Pin #20 (VCC) =19,33v
                                  Pin #16 (REGN)=5.99v
                                  • mon2
                                    • Dec 2019
                                    • 14239
                                    ACOK is NOT OK.
                                    What is the voltage to ground of the ACDET pin ?
                                    • Tend0
                                      E.E.C.S
                                      • Oct 2021
                                      • 92
                                      • Burkina Faso
                                      Acdet= 2,65
                                      • mon2
                                        • Dec 2019
                                        • 14239
                                        ACDET is ok.
                                        Confirm the presence of resistor @ PR425. Measure the voltage to ground on each pin of this resistor.
                                        One side should be the same voltage as REGN pin = ~6 volts.
                                        Then remove all power -> meter in resistance mode.
                                        Check the resistance to ground of the ACOK pin. Based on the information posted, ACOK should not be @ 0 volts. This is an open-drain pin so the pull-up resistor @ PR425 is required.
