Need Bios Dell latitude e5440 - s-tag C938N32
This topic is closed.
  • deja vu
    • Jan 2024
    • us
    I need Dell Latitude E5440 Bios
    Service tag - C938N32
    Express service code : 26671025630
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    Thread closed.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • gizaha
      by gizaha
      02-13-2024, 07:18 AM
    • Sathsul
      Dell Latitude 5431 issues with dumping bios
      by Sathsul
      So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
      The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
      However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
      10-28-2025, 07:49 AM
    • jhanra
      by jhanra
      11-02-2024, 04:19 AM
    • YOUCEF4787
      Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
      by YOUCEF4787
      I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
      Initial Problem:
      The laptop was completely dead, no signs of life, no power LED.
      Action Taken:
      I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
      Current Situation & The Main Issue:
      The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
      09-21-2025, 12:19 PM
    • TripTop
      Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
      by TripTop
      Hi
      i have dell latitude E7270 with following symptoms:
      - takes long time to restart.
      - sometimes powers on and then off
      - sometimes while working it just dies,
      From googling online bios clean could possible resolve this?
      i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
      As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
      I reinstall...
      09-09-2024, 02:05 PM
