820-00165-A green to orange no fan
  • koby058
    • Jan 2017
    • 382
    • israel
    Hi
    Macbook air not power on. fan not auto starting
    PM_RSMRST_L is 3.3v
    PM_SLP_S5_L is low
    Can you please help me diagnose?
    Attached relevant part of logiwiki map
  • mon2
    • Dec 2019
    • 14220
    Re: 820-00165-A green to orange no fan
    Hi Mr. Jaffa oranges
    1) What is the voltage value to ground of PPBUS_G3H ?
    2) What is the voltage value to ground of PP3V42_G3H ? Do you see the standard green / orange lights on the magsafe connector? If not, that needs to be fixed before proceeding further.
    3) Assuming the above voltages are ok, review the attached shorting pads on the PCB. Using tweezers, short one of the pair of pads to mimic the ON/OFF button.
    • koby058
      • Jan 2017
      • 382
      • israel
      Hi mon2
      Standart green to orange present.
      PPBUS_G3H = 8.51
      PP3V42_G3H = 3.4 (I think this multi meter is not the best)
      I could not understand what pads should be shorted to ground from the attached
      • mon2
        • Dec 2019
        • 14220
        These are good voltages.
        Apple / Foxconn / PCB designers apply SMD shorting pads onto the TOP and BOTTOM side of the PCB layout.
        This is so you can remove the keyboard & trackpad and still turn on the logic board.
        These pads for this logic board are @ R5115 & R5116.
        Varying with how the logic board is on your table, you will find one pair only and these pads can be shorted with tweezers.
        See attached.
        • koby058
          • Jan 2017
          • 382
          • israel
          Got it.
          I have shorted them to ground but still Fan not powering on
          just to mention I have 3.3v on pin one of R5115
          What do you think?
          • mon2
            • Dec 2019
            • 14220
            Yes, that voltage is ok and is active LOW. So when you short with tweezers to GROUND, the logic board will turn ON. From memory, believe that you should have fan spin if all is well even without this shorting of the pads.
            Review this excellent website that details the power up sequence of the same logic board:
            https://www.it-tech.com.au/mac-q-a/pm-slp-s4-l-timing/
            Continue to post your updates.
            • koby058
              • Jan 2017
              • 382
              • israel
              I have checked all voltages under this list in the link:
              "If PM_SLP_S4_L missing, we need to check these before replacing the CPU/PCH."
              and all are present, i don't have oscilloscope so did not tested SYSCLK_CLK32K_RTCX1 (RTCX1)
              some times the macbook does start.
              Maybe the PCH is done i don't know
              • mon2
                • Dec 2019
                • 14220
                When the board is NOT working, what is the voltage to ground of ALL_SYS_PWRGD ?
                Are you testing with only the adapter is there also a battery connected?
                Do go through the checklist from the above website - see attached.
                • judamex
                  Active Member
                  • Jan 2021
                  • 183
                  • Mexico
                  Originally posted by koby058
                  Hi
                  PM_RSMRST_L is 3.3v
                  PM_SLP_S5_L is low
                  i have the same problem, and my measurement on ALL_SYS_PWRGD = 0V
                  • mon2
                    • Dec 2019
                    • 14220
                    From the same above website..
                    A valid ALL_SYS_PWRGD signal checks these power rails: PP1V8_S3, PP5V_S3, PP1V2_S3, PP1V05_S0, PP5V_S0, PP3V3_S0, PP1V5_S0. Any of these S3 or S0 state power rails malfunction will pull down the ALL_SYS_PWRGD signal and terminate the normal power-on process of Apple computers.
                    Check the voltage to ground of each of the above power rails.
                    • koby058
                      • Jan 2017
                      • 382
                      • israel
                      ALL_SYS_PWRGD not present, testing with out battery. i did go through all this check list
                      • koby058
                        • Jan 2017
                        • 382
                        • israel
                        None of them is present.
                        when i measure like, let say PP1V8_S3 the minute i plug the charger i see some voltage and immediately back to zero
                        • dellxps15
                          • Feb 2014
                          • 1588
                          • italy
                          post bios pin voltage, check if u have 5 volt s4 pulsing, post voltage of u1950
                          • judamex
                            Active Member
                            • Jan 2021
                            • 183
                            • Mexico
                            The Value of all are "0.0V" except "PP3V3_S0" is too low "0.06V"
                            • judamex
                              Active Member
                              • Jan 2021
                              • 183
                              • Mexico
                              Voltage on U1950
                              1=0V
                              2=0.06v
                              3=0V
                              4=GND
                              5=0V
                              6=0V
                              7=0V
                              8=3.4V
