HP 15 LA-C701P not turning on
  • bilalinfotex
    • Aug 2021
    • 22
    • algeria
    hello friend i ma new here , First, thanks for all your helpful posts .
    I have HP 15 LA-C701P motherbord not turn on , no 3.3valw no 5valw .
    5/3 ldo are ok
    entrep 1 and 2 = 0v
    ec_on = 0v
    With diode mode maltimetter show 12 with beep (it normal??) on pl8 (5valw coil) .
  • Sephir0th
    • Oct 2020
    • 1267
    Re: HP 15 LA-C701P not turning on
    Sound like a short to GND. What's the reading in Ohms Mode, low range (200 or sinilar)?
    FairRepair on YouTube
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Did you measured resistance immediately after power plugged in?? If yes, you may get weird value. Allow caps to discharge for some time and then measure again.
      • bilalinfotex
        • Aug 2021
        • 22
        • algeria
        Thanks for the answer , there is no short to GND i already inject 5 v .
        Please , I want to know how to judge the resistance (what is the normal value and at what point we can say it a short ).
        • lapfix
          • Mar 2020
          • 2719
          • my workshop
          Never inject more than 1 volt ! it's a critical you can distroy other component
          start by first step :
          Voltage at D/G/S of PQ 202 and PQ 203
          What's the consumption with/without ram
          RTC section :
          voltage of JCMOS1 = PCH_RTCRST# and JME1 = PCH_SRTCRST#
          • bilalinfotex
            • Aug 2021
            • 22
            • algeria
            Thanks for the answer .
            YES i measured resistance immediately after power plugged in and the value keep changing .
            tank you for help
            • mon2
              • 14077
              You cannot measure resistance or diode mode if there is power to the logic board !!! Confirm this.
              If you have power to the board, remove it and allow some time to discharge the capacitors, then check the resistance without any power. 30 seconds or more is enough to discharge the caps.
              • bilalinfotex
                • Aug 2021
                • 22
                • algeria
                [QUOTE=lapfix;1185748]Never inject more than 1 volt ! it's a critical you can distroy other component
                yes first i inject 1.2 v When I did not find a voltage drop i inject 5 v
                Voltage at D/G/S of PQ 202 and PQ 203 are ok 19v / 25v /19 and ACOK is 3v so i tink that charging section is ok .
                I dont have power supply to measure consumption with/without ram i am useing old motherboard and take 1.2 v from cpu supply it working with me .
                but I will buying one soon .If so, I would like to know how to use consumption in troubleshooting laptop .
                • bilalinfotex
                  • Aug 2021
                  • 22
                  • algeria
                  thank you for your help
                  • bilalinfotex
                    • Aug 2021
                    • 22
                    • algeria
                    RTC section :
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      You dont answer the questions properly and completely. You dont have a dc supply also. It'll be difficult to proceed further.
                      Check the basic requirement of SIO and answer these queries:
                      01.Is dc jack light glowing?
                      02.Battery charges??
                      03.Check whether 3V and 5V is generated on coils just after adapter insertion. Voltage should be available on coils for a few seconds only as Deep Sleep Well is involved here.
                      • totto210
                        hp 17-k dont start , problem with 5valw (no 5vs5_on) day31amb6c0 rev c
                        by totto210
                        Hi guys, I need a big help.
                        i don't have 5valw, (pu12)
                        the signal (pin 1) from pu12 has 0,11v.
                        I go back and it comes straight from the EC (pin128) same thing, no sulfate or anything.
                        then looking at the diagram I see that pr185 is not present, but if you have 3.3v so I make the bridge, now the mother is with a consumption of 50ma put the source. but there is no case nor responds the power button.
                        With this if I have 5valw.
                        I leave measurements I made
                        u3 bq738h
                        1 19.5v
                        2 19.5v
                        4 25.4v
                        5 3v
                        6 2.71v
                        11 2.9v (without battery)...
                        10-14-2024, 09:12 PM
                      • seppde
                        Dell XPS 9380 No Power - After providing 3VALW and 5VALW once, they persist - still no power-up
                        by seppde
                        I've recently gotten my hands on a defective XPS13 9380. I will attach a zip of the schematics and boardview.
                        My first discovery on the Board was that the reverse current Diode PD103 of the 1st USB-C was blown.
                        Nothing to worry about, the board got 3 USB-C ports which support Power/Charging. On I go.
                        Next I inspected the power-rails to see why the diode blew up and found a short on the 3V3 rail which I traced back to the Power-IC for the LCD (UZ2). I desoldered it and the very low-ohmic short is gone. I checked on the LCD-connector that there's no short...
                        10-01-2024, 10:57 AM
                      • Sparklingx
                        HP 450 g1 keeps turning on even tho shutdown/sleep
                        by Sparklingx
                        HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                        09-23-2024, 12:34 AM
                      • khelane
                        Satellite PRO A50-A Not turning on after turning off Windows
                        by khelane
                        Hello
                        A device with specifications
                        Toshiba Satellite PRO A50-A is here to replace the hard drive.
                        The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
                        The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
                        04-20-2023, 06:28 AM
                      • Rabit
                        VX3276-2K-mhd-2 Random Turning off
                        by Rabit
                        Recently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
                        When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
                        This can be signs of bad capacitors causing overheating PSU ?
                        06-17-2024, 09:30 AM
