Lenovo Thinkpad E15 board NM-D011 power
  • warsztat
    • Feb 2017
    • 190
    • Polska
    Hi, Lenovo Thinkpad E15, board NM-D011 problem with power in USB-C.
    The problem is the low voltages on the gates of the transistors as shown in the pic1.
    The slightly conductive transistors got very hot until they broke the connection.
    Transistors need 4.5V at the gates to conduct, so the voltage should be around 25V.
    It seems that the fault is in the transistor control system, in the photo TP565994, I found a pdf TPS65994 which is probably the same system in a different housing.
    If I understood the pdf correctly, the system is programmable, so buying a new one without software will not be successful. Please correct me if I misunderstood it.
    TP565994 works with UB9 CAT24C256 memory, so it's possible that there is some configuration in it. I wonder if reprogramming this memory wouldn't solve the problem. I'd like to try a file for it.
    Regards.
    MOD Edit - link to schematic https://www.badcaps.net/forum/showthread.php?t=106574
    https://cdn.badcaps-static.com/pdfs/...ca08711b51.pdf
  • mon2
    • Dec 2019
    • 14211
    Re: Lenovo Thinkpad E15 board NM-D011 power
    These are N-channel mosfets so yes, the gate should be HIGHER than the voltage being passed between source/drain pins to enable.
    Respectively, the voltage should not be passing if the gate voltage is so low at 4v5.
    Remove all power. Remove fuse F6101 for now.
    Power up again. What is the voltage to ground of the 2nd dcin mosfet at F6101 pcb pads? It should be ~0 volts.
    If not, remove all power, meter in resistance mode.
    Measure the resistance across:
    Source (1-2-3) & drain (5-6-7-8)
    Source (1-2-3) & gate (4)
    Gate (4) & Drain (5-6-7-8)
    Post each measurement. Do these checks for each of the DCin mosfets. Suspecting that the 2nd mosfet (at least) is defective and leaking.
    • rediii
      h???, spurrrn
      • Mar 2018
      • 487
      • somewhere in europe
      Regards.
      i doubt that they are programmed, these usb c controllers tend to fail, especially when using fake chargers
      • warsztat
        • Feb 2017
        • 190
        • Polska
        Thanks for answers.
        I replaced both transistors with AON7400 which seem to be good replacements but the effect is the same, the voltages are as in Fig.1. No VINT20 voltage without transistors.
        Using a tabletop power supply set to 25V, I applied this voltage through 68 kohm resistors to the gates of the transistors, but the TPS pulled it down to 20.6V as if it were a zener diode.
        • Sephir0th
          • Oct 2020
          • 1282
          It can't work like this.
          You want a dodgy solution? Then just jumper the mosfets. Of course you would lose some important protection for the board, so nobody serious would share a advise like that.
          Otherwise we need more informations. What voltages do you get at VCC3_LDO_PD, ACDCIN1, ACDCIN2 and TBTA_VBUS20? Resistance to GND of VINT20_IN?
          FairRepair on YouTube
          • warsztat
            • Feb 2017
            • 190
            • Polska
            1. VCC3_LDO_PD ~ 84Kohm for GND, voltage = 3,44V.
            2. VINT20_IN over range, in the diode test the same no resistance to GND, voltage = 18,3V.
            3. TBTA_VBUS20 ~ 135Kohm, voltage with power supply = 20,3V.
            Power Supply Lenovo 65W USB-C after plug voltage 5V changes to 20,3V so control works.
            I find only a similar boardview, haven't found ADCIN1 and ADCIN2 yet.
            I bridge only QB6 mosfet, then the laptop can be turned on and the battery charging works but the qb5 heats up because there is a voltage drop on its diode.
            The voltage at the QB5 gate is 0.3V higher than the voltage from the power supply, so something is going on there.
            I hope I am understood, sorry for the mistakes.
            ADCIN1 = 0,4V
            ADCIN2 = 3,5V
            I think the are correct.
            • warsztat
              • Feb 2017
              • 190
              • Polska
              I noticed that the UB7 heats up after a while, I missed it before. It's too hot.
              Thank you all very much, best regards.
              • rediii
                h???, spurrrn
                • Mar 2018
                • 487
                good luck!
                • kris-ark
                  • Aug 2023
                  • Poland
                  Cześć, czy poradziłeś sobie z tym problemem zasilania w NM-D011 bo mam taki sam przypadek i już kopie temat dłuższy czas i nic.
                  Myślisz, że TP565994AD jest programowalnym układem?
                  Hello, did you manage to solve this problem in NM-D011 because I have such a case and I've been digging through the topic for some time and nothing.
                  Do you think TP565994AD is a software chip?
                  • mferna14
                    • Jun 2018
                    • 1020
                    At the back of this board NM-D011., there two MOFETS AON7400 x 2... Kindly remove both the MOSFETs, you will notice the dry solder on the pads. Now either replace them with new one & use larger AMPs MOSFETS or clean these FETs with alcohol & add new solder. The original are 30A but I used AON7702 which is 37A & after this replacement use a rubber coolant pad covering the IC & both the MOSFETs, the problem get resolved. Try it & you might figure out yourself.
                    • mustangank
                      • Jun 2021
                      • 27
                      • Türkiye
                      Thank you very much
                      • ctebke
                        • Sep 2014
                        • 36
                        • Serbia
                        Hello, I have the same problem. the transistors got so hot that they unsoldered themselves. I put another pair of transistors n FET 30V 30A and I put a thermalpad. The laptop works, but that part with the thermal pad heats up to 80 degrees, also the coil that goes to the battery at 80 degrees. Is there perhaps another cause? Thanks ...
                        • rumpumpel1
                          • Jul 2019
                          • 149
                          • germany
                          https://www.youtube.com/watch?v=FQM0cDefHi4
                          • PC_Sauna
                            • Oct 2024
                            • 4
                            • Finland
                            I have similar problem. PD doesn't start and 'spread' on motherboard.
                            On one forum a guy said that TPS65994AD controller has external firmware which is stored in CAT24C256WI-GT3_SO8.
                            Could someone please share the dump of this EEPROM?
                              • 20914
                              PD Firmware, post 25 https://www.badcaps.net/forum/troubl...07#post3601007
                              • ub6ib969
                                • Jul 2010
                                • 198
                                hi,
                                unit is a : Lenovo ThinkPad E15 Gen 2 GE4B0 motherboard with the infamous QB6 mosfet de soldering off the board, however the usb c port was replaced by another shop not know the common issue. I replaced the qb6 with a AON7466 however the UB7 started to get really hot and unit would not turn on. I then replaced the UB7 and QB5. I now get 0V on VINT20_IN_F and VINT20_IN on both sides of F6106, however when I inject 12v on either side the unit boots up. Can this be an issue with the USB-C port not soldered properly? I so get 20V 0.039A on the usb-c meter.
                                TBTA_GATE_VSYS
                                =9V
                                1 TBTA_GATE_VBUS
                                =28.7V
                                1 N107911352
                                =0V
                                1 TBTA_VBUS20_F
                                =20.3V
                                2 TBTA_VBUS20
                                =20.3V
                                QB5 PIN 1-2-3 i am only getting 0.3v however this is a new mosfet.
                                any help would be great !
                                • mon2
                                  • Dec 2019
                                  • 14211
                                  20V 0.039A
                                  Since you have 20v, the power delivery contract communication is working. The TBT controller has chatted with the external power adapter, extracted the capability list and then selected the best power delivery contract to power this board.
                                  Remove all power. Meter in resistance mode. Measure the resistance of the new mosfet.
                                  source / drain
                                  source / gate
                                  gate / drain
                                  Share each measurement for a review. Each should be hundreds of k ohms or higher else the mosfet is a suspect. Have not checked the schematics but is the replacement mosfet of the same type? That is n-channel for n-channel or p-channel for p-channel?
                                  • ub6ib969
                                    • Jul 2010
                                    • 198
                                    the unit is now working. The issue was J6 didn't have solder on the pads .
                                      Lenovo ThinkPad ThinkPad E14 Gen 2 (Intel) Notebook E Specification for Upgrade or Repair
                                      This specification for the Lenovo ThinkPad ThinkPad E14 Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E14 Gen 2 (Intel) boardview and ThinkPad E14 Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-07-2024, 05:20 AM
                                      Lenovo ThinkPad ThinkPad X1 Fold Gen 1 Ultrabook X Specification for Upgrade or Repair
                                      This specification for the Lenovo ThinkPad ThinkPad X1 Fold Gen 1 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Fold Gen 1 boardview and ThinkPad X1 Fold Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      Lenovo ThinkPad ThinkPad P17 Gen 1 Notebook P Specification for Upgrade or Repair
                                      This specification for the Lenovo ThinkPad ThinkPad P17 Gen 1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad P17 Gen 1 boardview and ThinkPad P17 Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-07-2024, 05:00 AM
                                      Lenovo ThinkPad ThinkPad E15 Gen 2 (Intel) Notebook E Specification for Upgrade or Repair
                                      This specification for the Lenovo ThinkPad ThinkPad E15 Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E15 Gen 2 (Intel) boardview and ThinkPad E15 Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
